hey mate,
the fastest gtst i have ever been in had the apexi RX6 turbo kit & mild cams...i think it had dyno'ed 290kw @ wheels.
great spool/response as well..the guy was trying to sell it to me and took me for a spin around mt cootha in it....lets just say it didnt have any problems cutting the rear wheels loose...LOL
i can try and find the guys detials if you want, he started a workshop near mercury ms
ok kewl that would be great if you could.... i just heard about them and wanted to find out a bit as they seemed a very good direct replacement turbo..
these are awesome turbos but in a r33 with tune and cams wont boost till 3500-4000..u would def need to rebuild the engine so it can be reliable!
if u like a kick in the pants rush then this is for you personally i think these shit on hks variants of the same output!
if i had 8k i would get one ..u can buy them as kits.
IHI make these suckers.
ohh so they are a bit laggy i take it... oh well i have have seen laggier i was just thinkin of runnin 10psi till i get a DECENT front mount and computer an then injector and fuel pump..
what sorta power do you think i would be gettin with,
stock engine
hks pod
full custom turbo back zorst
an runnin 10pound..??
stock engine
hks pod
well also depends on tune and what u have done to the motor!
not sure about power youll be making but i know a red r33 had one was making 330rwkw's with stock internals and drove it aorund for 9months like that at 18psi....mmmmm
if u get one get small exhaust housing will spool up quicker!
would any1 also be able 2 make a guess as 2 what i would find 1 for 2nd hand with low K's..?
thank you
hey,
i was looking at buying this turbo before i got my HKS one.
The Apexi Rx6 comes in may forms, if you go to the apexi website, there is a pdf file which tells you the differences between each model.
The one i was going to buy was the 450hp RX6 and it came with a Manifold, Wastegate and Dump Pipe; it was on yahoo-auction and it ended up selling for just alittle bit over $2000
here a photo of it:
p.s the turbo is only oil cooled and if you cant find a REAL apexi one, you can always get the IHI one (IHI is the garrett equivalent)
Cheers Michael :P
http://www.nissansilvia.com/forums/index.p...ic=140673&st=30
check out the vid half way down the topic the gold 33 has a rx6 turbo smoke show oh and Im in the grey 32 4 door near the end
we also had one on a r33 wt 2.7lt motor it made 355 rwkw on 1.8 bar at the last SA dyno day
