B0BB0 Posted January 31, 2006 Share Posted January 31, 2006 Hey guys, I have ran a 10 in my gtr, and i have been told not to come back untill the car meets andra requirements. the thing that i am stuck on is the rollcage/halfcage, i am still undecided if i will weld a car in the car or not, as i use it almost everyday. I was just wondering does anyone have any pics of halfcages that have meet the andra requirements ? and if so could you post them up for me to see. Cheers Bobbo Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/ Share on other sites More sharing options...
gtr660hp Posted January 31, 2006 Share Posted January 31, 2006 Talk to Theo Woolett or Mark Jacobson (both in QLD)-they will know the go, as both guys have run ANDRA complianced 9 sec GTR's for a while now Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1911848 Share on other sites More sharing options...
Mick Posted January 31, 2006 Share Posted January 31, 2006 i have a full cage, bolt in for a r33 Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1912028 Share on other sites More sharing options...
MS-75 Posted January 31, 2006 Share Posted January 31, 2006 A completely bolted in half-cage is not compliant - according the current ANDRA Tech Director Ken Dickie. At least the main hoop must be welded into the car. (back-stays and side intrusion bar may be bolted in.) Unfortunately however, due to the description present in the ANDRA hand book, this point is not clear (along with a boatload of other stuff-the ANDRA rulebook is rediculously light-on) I have been through the process of sorting what is and isn't compliant in the last few days as I am having a cage fitted to my car at the moment. A full cage(minimum 6-point) is required for 9.99 and under, and the half-cage (4-point) for 10.99-10.0. Hope this helps Sean Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1913530 Share on other sites More sharing options...
Swiper the Fox Posted January 31, 2006 Share Posted January 31, 2006 A completely bolted in half-cage is not compliant - according the current ANDRA Tech Director Ken Dickie. At least the main hoop must be welded into the car. (back-stays and side intrusion bar may be bolted in.) Unfortunately however, due to the description present in the ANDRA hand book, this point is not clear (along with a boatload of other stuff-the ANDRA rulebook is rediculously light-on)I have been through the process of sorting what is and isn't compliant in the last few days as I am having a cage fitted to my car at the moment. A full cage(minimum 6-point) is required for 9.99 and under, and the half-cage (4-point) for 10.99-10.0. Hope this helps Sean <{POST_SNAPBACK}> Here's a pic of the front of ours...its a 6 point weld in. Full pics can be seen in the last HPI GTR special (the one with Garage Saurus R32 on the cover) Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1913745 Share on other sites More sharing options...
1JZ.747 Posted January 31, 2006 Share Posted January 31, 2006 i have half cage in the cressida. sean is correct the main hoop must be weld in as set by ken dickie head of andra technical. rear stay can be bolt in, i had mine welded in side intrusion can be bolt it. i did this so the car is street legal. JP fabrications on the central coast did mine, i was happy with the job and the price. speak to buster i believe he is in the process of getting a cage also. Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1914414 Share on other sites More sharing options...
Mick Posted February 3, 2006 Share Posted February 3, 2006 (edited) Well i have a full 6 point bolt in cage for an r33 if your interested. You can easily weld it in instead of bolting it in .. Its fully padded in blue padding, i beleive its cusco brand. Im looking for $800 Edited February 3, 2006 by Mick Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1922904 Share on other sites More sharing options...
B0BB0 Posted February 4, 2006 Author Share Posted February 4, 2006 jap cages dont have the required wall thickness Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1923367 Share on other sites More sharing options...
SRB Posted February 5, 2006 Share Posted February 5, 2006 im hoping to run in the high 10s with my car.. the car will be QLD registered. does anyone kno the rules n regulations for a qld rego car? i wanna keep it QLD street legal and have it all plated so... can i put in a 6 point cage? do i get a half cage? what do i do? thanks, Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1925705 Share on other sites More sharing options...
NA_R33 Posted February 5, 2006 Share Posted February 5, 2006 in qld to be street legal cars have to have a bolt in cages not weld in.... as stated in the light vehicle modification book... the way around this is to do both, weld it in put bolts through it and hope for the best. Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1925826 Share on other sites More sharing options...
Sydneykid Posted February 5, 2006 Share Posted February 5, 2006 jap cages dont have the required wall thickness <{POST_SNAPBACK}> I have measured a few Jap cages and the wall thickness has been fine. The Japanese standard allows the same size pipework in all elements of their roll cages. The main problem is the main hoop OD is smaller than the ANDRA and CAMS standards. The other pipework elements are OK. cheers Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1926089 Share on other sites More sharing options...
Mick Posted February 8, 2006 Share Posted February 8, 2006 the 6point bolt in i have is very very solid Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1932389 Share on other sites More sharing options...
raz0r$harP.UK Posted February 8, 2006 Share Posted February 8, 2006 the 6point bolt in i have is very very solid <{POST_SNAPBACK}> Doesn't help if it won't pass a tech inspection. Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1932486 Share on other sites More sharing options...
I LIKE SAUSAGES Posted February 8, 2006 Share Posted February 8, 2006 Doesn't help if it won't pass a tech inspection. <{POST_SNAPBACK}> will some1plz post some pics up so i can make my cage i need some ideas and connection points plz......... Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1933995 Share on other sites More sharing options...
Remix- Posted February 28, 2006 Share Posted February 28, 2006 My 6 point bolt-in... Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1985403 Share on other sites More sharing options...
MrBlonde Posted February 28, 2006 Share Posted February 28, 2006 Bolt in cages or rollbars are not ANDRA compliant. Listen to those in this thread who have actually done it and obtained ANDRA tech inspection approval. Link to comment https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1987012 Share on other sites More sharing options...
