Hey guys,
I have ran a 10 in my gtr, and i have been told not to come back untill the car meets andra requirements.
the thing that i am stuck on is the rollcage/halfcage, i am still undecided if i will weld a car in the car or not, as i use it almost everyday. I was just wondering does anyone have any pics of halfcages that have meet the andra requirements ? and if so could you post them up for me to see.
Cheers
Bobbo
https://www.sau.com.au/forums/topic/103983-rollcage-help/
A completely bolted in half-cage is not compliant - according the current ANDRA Tech Director Ken Dickie. At least the main hoop must be welded into the car. (back-stays and side intrusion bar may be bolted in.) Unfortunately however, due to the description present in the ANDRA hand book, this point is not clear (along with a boatload of other stuff-the ANDRA rulebook is rediculously light-on)
I have been through the process of sorting what is and isn't compliant in the last few days as I am having a cage fitted to my car at the moment.
A full cage(minimum 6-point) is required for 9.99 and under, and the half-cage (4-point) for 10.99-10.0.
Hope this helps
Sean :P
https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1913530
Hope this helps
Sean :P
Here's a pic of the front of ours...its a 6 point weld in. Full pics can be seen in the last HPI GTR special (the one with Garage Saurus R32 on the cover)
https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1913745
i have half cage in the cressida.
sean is correct
the main hoop must be weld in as set by ken dickie head of andra technical.
rear stay can be bolt in, i had mine welded in
side intrusion can be bolt it. i did this so the car is street legal.
JP fabrications on the central coast did mine, i was happy with the job and the price.
speak to buster i believe he is in the process of getting a cage also.
https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1914414
Well i have a full 6 point bolt in cage for an r33 if your interested. You can easily weld it in instead of bolting it in .. Its fully padded in blue padding, i beleive its cusco brand. Im looking for $800
Edited by Mick
https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1922904
im hoping to run in the high 10s with my car.. the car will be QLD registered. does anyone kno the rules n regulations for a qld rego car? i wanna keep it QLD street legal and have it all plated so... can i put in a 6 point cage? do i get a half cage? what do i do? thanks,
https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1925705
in qld to be street legal cars have to have a bolt in cages not weld in.... as stated in the light vehicle modification book... the way around this is to do both, weld it in put bolts through it and hope for the best.
https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1925826
jap cages dont have the required wall thickness
I have measured a few Jap cages and the wall thickness has been fine. The Japanese standard allows the same size pipework in all elements of their roll cages. The main problem is the main hoop OD is smaller than the ANDRA and CAMS standards. The other pipework elements are OK.
:P cheers ;)
https://www.sau.com.au/forums/topic/103983-rollcage-help/#findComment-1926089
  • 3 weeks later...
