I have a neo RB25 det engine out of an r34 with a manual gearbox attached. Was wondering if anyone had any advice on how to drop it into a VL commodore. I know i should be putting it in an s13 or r32 etc but i already have an r33 and me and a friend want a sleeper. Anyone know which tail shaft i can use and if the rb25 engine mounts will bold straight onto the VL cross member? Any onfo would be much appreciated.
Nate.
https://www.sau.com.au/forums/topic/103986-neo-vl/
Nate.
rb30 vl engine mounts (shimed on the right hand side for break booster clearance
vn-vp auto or manuel (cant rember) gearbox crossmember (something like that)
std vl tail shaft using the yolk out of the neo,with a diffrent uni-joint to mount to the vl shaft
will need to up grade the fuel pump, need to modify the p/steering pump mounting bracket, a/c std vl bracket with washers under for spacers
throttle cable i use the std but the cable is much tighter and is wraped diffrentley and looks crap (i thnk the neo has a electric butterfly also but no idea what its for.
then the obvious computer and loom needs to be modifyed to work with the vl bodey loom for starter motor and alternator etc
(my rb25de) i changed the lower radator hose intake pape (to the motor where the thurmo stat is mounted) to the vl one as i was reusing the lower vl radator hose may also need to do that if u like.
i also used a cut lower radator hose for my top hose and the 2.5's are diffrent but u might be able to do something else
all in all there isnt much that needs to be done
https://www.sau.com.au/forums/topic/103986-neo-vl/#findComment-1912595
Nathan,
There is a guy in my area with the exact same setup - only he is near finished :D
If you want I can get you some contact details :D
For starters look at this:
http://www.tuned4street.com/index.php?showtopic=4116
https://www.sau.com.au/forums/topic/103986-neo-vl/#findComment-1912724
This VL is stockers as externally. Put it this way, when i'm in my skyline, i believe i can beat any commonwhore on the roads, which is true in most instances. The car i'm putting the rb25 DET in is a plain white VL commo. That is a sleeper, especially after i'm done with it.
https://www.sau.com.au/forums/topic/103986-neo-vl/#findComment-1929236
mate just make sure u have mudflaps, dashmats, 15' intercepters with hub caps, nudge bar, tow ball, extra view rear vision mirrors(the ones u use with a caravan) etc.... and it will be sweet.
oh yeh i think the standard vl crossmember will bolt up to the gearbox(if its the same as the r33 gbox)
it'll be a tight fit but gl.
Edited by joe2548
https://www.sau.com.au/forums/topic/103986-neo-vl/#findComment-1937141
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
