I replied to the R33 idling problem thread but to no avail. So i'll make a new topic.
After driving around for like half an hour and then park it, when starting up again the car will idle really low (from like 800 (normal) down to when it sometimes stalls). But after say 5 minutes it's all good again. Any ideas people?
Thanks
Scott
https://www.sau.com.au/forums/topic/10399-idling-problem-with-r32-gts-t/
Someone asked the same question in another thread, someone else suggested that it was the earth wire coming from the fuel pump. He said it needed to be earthed to a new area near the rear of the car. This way the fuel pump will operate at 100%. all the time. check the thread out, its in the 'performance' part.
When some dicks replaced the timing belt on my car (under warranty) he had it 1 tooth out on the exhaust cam.
This made it chew the fuel and idle weirdly. It would move up and down from 800 - 1200 rpm.
Once you turned the Air-con, it nearly stalled.
I don't think this is your problem, but you could always check it out.
Check the AAC valve, and clean it. Its the little valve located at the back of the plenum chamber (inlet manifold). Its what controls the air bleed at idle. Works like a screw moving a needle valve. If the screw or needle gets sticky, it lurches rather than run smoothly.
Where can i find the fuel filter? Is it the big metallic cannister thing below the intake plenum thats fairly visible and has a big clip to hold it to the chasis? Is it the one with the tube that goes in the bottom, and the tube that comes out the top and towards the fuel rail, or is it further back near the fuel tank, e.g. under the car? I should check mine i guess, although my problem is not on idle, but more under foot to the floor condition.
Just that on previous cars they've been much smaller.
    • Awesome mate, sounds like an awesome car! My 33 has the 400R/Nismo front and rear bumpers and side skirts. They're in terrible condition though so I either need to fix them up or toss them and get new, standard bumpers and skirts. I wish the Nismo stuff was FRP not fibreglass as they're always one nudge away from complete destruction!
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
