I just bought an all in one split dump/frontpipe.
The all in one design allows the wastegate pipe to be much longer than the HKS style split dump and separate frontpipe combo.
This is supposed to reduce turbulence therefore improving the flow.
Some say that the all in one bellmouth type can make more power in the top end than either of the split types when running high boost but not everyone agrees with this.
Do a search and make up your own mind.
i was origianally going to go for a split style one... from marky at Exhaust technology (SA)
However he informed me that with the stock O2 sensor, they apparently have 3 prongs or somethin like that, and one of those sensors registers the heat expelled out of the turbo/wastegate.
now if your on full boost for a while (ie long hills thrash) then the air coming out of the wastegate pipe is much hotter than waht the O2 sensor (in the front pipe still) is reading.
Dont know exactly how this effects the computer etc of a stockish car..... but marky informed me to simply go for a bellmouth design.
yer the one in looking at is an all in one screamer and front pipe, so its like a normal front and dump all in one pipe but the seperate wastegate pipe doesnt join back into the exhaust. So what do you guys think ..
Hey im getting a split dump very soon, a stainless steel one that goes from turbo to front pipe.
How is the factory unit restrictive???they look very similar in the pic above apart from the SPLIT design, is it just its flow capabilities of the stock one???
And i assume youll see the same amount of gains from going front/dump combo, or just the dump pipe unit itself with an aftermarket front pipe???
is it a good idea to have the split dump heatwrapped first?and how much wrap will i need?
Edited by nsta
  • 1 month later...
i was all in on getting one of the batmbl ones but after showing my friends they all say to get the greddy split dump and blitz front pipe because suposedly where the front and dump join has alot of stress and they crack easily there with the 2 in 1 designs,
and its actually happened on my mates s15 he had a 2 in 1 design and it cracked right where the dump and front would usally joing now he has the greddy & blitz combo!
around the same price as batmbls too
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
