Hi guys! Man, long time no see for all u guys. I been gone for quite a while. Good to be back tho B)
My R33 has finally reached the age of 100,000 kms now and so its time for a major service. I know there is a thread about this major service and I read it, but I was hoping for VICTORIAN experiences with this major service.
- What was done (other than timing belt)?
- Who did u go with?
- What was the cost?
- Any other problems that needed addressing during or after?
Any posts appreciated. Thanks all!!
BTW, this is the list of tasks that the 100,000km service thread mentioned (I'm scared of the bill!!):
New Iridium Spark Plugs.
Water Pump.
Thermostat
Cam belt
Drive belts.
Oil Filter
Fuel Filter
Check cam and crank seals for leaks usually OK and extra if seals required
Check cam belt pullies
All electricals, exhaust, suspension. Coolant and hoses.
Gear oil 75w- 90 or auto trans service.
Engine, gearbox and power steering get Uniglide treatment.
Clutch and brake fluid flushed and bleed.
Radiator and engine flush.
Clean and treat battery terminals.
Clean terminals to injector plugs, ignition coils.
Compression test.
Spray lubricant on throttle linkages and other.
Adjust water sprayers and additive used
Lubricate door hinges and strikers, bonnet latch, boot hinges, aerial mast.
Check and tighten sub frame and suspension and cross member bolts etc.
Tyre pressures checked and corrected.
Air filter replaced or if performance filters cleaned and re oiled.
Check list for our technicians and report given.
https://www.sau.com.au/forums/topic/103994-100000km-major-service-suggestions/
ice performance
timing belt and 100k service
all fuilds, plugs, check brakes, check suspension
brake pads/rotors were fine + bushes to be done at 140 ish
most performance places that i can think of wont touch
Water Pump.
Thermostat
Cam belt
Drive belts.
the rest should be ok however
there some people who insist on replacing the water pump at 100,000
i dont see a pressing need for it, i mean why do that and not the oil pump? they are both as equally as important. unless im missing something?
the 100,000 service will cost around $600 mark ish
and the timing belt change will cost around $450 byitself
so $1200 is ballpark providing they find no major problems
do your water pump!!! i didn't do it for my 100,000k service only to find 6,000 later that it was shagged...
paul, the water pump circulates corrosive liquid so the seals tend to die at about 100k oil pumps don't corrode parts like coolant does...
ice performance
Water Pump.
Thermostat
Cam belt
Drive belts.
i dunno about that... Gerald (ICE) regularly comes home after doing a 100k service and he changes the water pumps without a doubt.
Other stuff, if you asked, im sure they can attend to.
Just remember, some stuff can be done yourself, like cleaning battery terminals and things like that. So you save labour hours by doing it yourself.
yeah sorry i should have said its minaly due to added labour costs
i mean i would prefer they did check my engine and crap instead of looking for sqeaky door seals and so on. paying a price for a performance workshop, may as well have them look at the performance stuff instead of imho oem car stuff which any mechanic place can do.
was unaware of water pump changes at 100,000
mine wasn't done that i know of
yeah u can have everything done but its just gonna crank up the price by stacks
Adz, how long is your car going to be out of action in the garage for? Did G give u an estimate? And also a quote on the cost? or is it a 'well, we'll see when we get there' type of thing (like usual)
Okies, water pump it is. Any suggestion on spark plugs??
hey king, u could always do most of them yourself and save a fortune, things like fluids,filters sparkies r easy but timing belt is a bit tricky
my dads friend is a good mechanic + he is very cheap for us so he did my timing belt and i told him to might as well do the water pump seeing as the belt was off
instead of paying $1000+ i payed like $400 doing most of the shit myself
he is doing it himself :D
youve got rocks in your head if you dont do the idler bearings......infact if i had to sacrifice....id sacrifice the water pump for the idlers....if the idlers let go your head has to come off.........if the water pump fails you leak water and the gauge goes up and you stop driving.......but id be doing both
yep, gotta do those idlers too if not already done
I think they are every 80,000 (or 70,000) arent they?
I had one let go many years ago. $1500 later as it smashed all 24 valves to bits, then the motor ate those yummt bits, and so the story went
wow...i would like to know where i could get the following parts for $400...
timing belt,both tensioners,plugs,cam seals,crank seal,waterpump,thermostat,tesioner stud,fuel filter,oil filter,engine oil,coolant,gearbox oil,diff oil,3 drive belts and the o2 sensor....any heads up?
Doin mine this Sat mate, will let you know how I go :)
I'm doing all seals, all belts including cam, water pump (becuase it's east to get to when doign the cam belt), O2 sensor (why not while I'm at it), all fluids, plugs etc...
Fun job wasn't it :O
-Patrick
