jus wondering if the airbox works with no afms? ill be getting piping n that mad up for it, the sole reason i want an airbox is for defect reasons...
I have an ARC airbox in my R32 GTR. There's no reason it wouldn't work if you had suitable adaptors made up to replace the AFM's.
Heres my mates one
As for defects, id suggest leaving the AFM's on - i do, just for the cops, incase i one day have to explain the reasoning for me to not use afm's being a microtech, which is ALSO a defect
(microtech dont use afm's, they use manifold pressure)
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
