hey everyone , i need help figuring out weather the problem is with the diff or the lsd because every now and then when i drive the car slow i get a clicking noise in my rear wheels i had a look under the car and the diff had a bit of a leak , could it be that i have no fluids in the diff or lsd?? please help.
https://www.sau.com.au/forums/topic/104008-lsd-or-diff-problem/
What do you mean by "every now and then"? Under what conditions do you get this "click"? Is it consistent that you will get it under a given circumstance?
The LSD is the diff, basically.
yes the lsd is the diff
lsd = limited slip differential
best bet would be to check the fluid levels in the diff and flush it if low
this gives the oppurtunity to check the gears, if they're worn that could be the noise
worn gears = new or recon diff
not that expensive but could dent hip pocket a bit
