what i mean is your car is tuned for 98. or whatever.
even with a self learning computer i'd think it would take alot of driving for it to learn the new may..
You could always reset the ECU, which should help it learn faster.
  • Replies 42
shell extreme is not made to go into any nissan before 1998. If you go onto shell site they have all the cars EXTREME is compatible with. So i prefer to stay with OPTIMAX or BP ULTIMATE
Remember only about a year or two ago there was uproar around service stations selling fuel with ethanol
Yeah whats the story with this, they were selling it at pump prices, the under the uncounter stuff, but now it costs an arm and a leg extra?
You need to differentiate between bodgy operators adding ethanol/toluene and or any other rubbish to the fuel to avoid excise & the proper stuff.
The legit stuff is good but you ned to be sure that your tune is ok with it.
a fellow nissan driver has done a write up about it's effects on his s15. Great information for any queries anyone might have.
http://www.waspperformance.com/forum/index.php?showtopic=212
Peace
Mykal
Thats exactly what i have noticed, my knock levels have reduced significantly
japanese fuel is 100RON
optimax extreme is 100RON
so, the STOCK ecu IS tuned for this fuel
the only difference is the ethanol additive which they have used to increse the octane rating.. will this damage your engine? at 5% of the blend, there will be sweet f-all going into your enging at any time, and i can't see how it could make a difference
i have tried it and like it
i give it an 8/10 and 2 thumbs up
I feel the same way mate, been using it since the first week it was released my car seems healthier and revs harder. I dont see what all the fuss is about 5 % wont do s#*t all, give it a try, u generally know if your car drives better or not if your in tune with it. u no like u no buy
Guest Mashrock
i dont beleive thats the case.. as the shell fuel has an additive to it. (ethanol) and it is alot more oxyginated than say japans 100ron fuel.
so once again,..
tuning is needed/
Simple - Throw a wideband on your car. Drive it and note the AF/R.
Then drain the tank and put Extreme in it - you will notice its leaned out by 1 ratio. (ie if it was 12:1 before, now it will be running 13:1)
This is due to extra oxygen and the reduced density of the ethanol.
Need tuning.
Would you care to do the mathematics on that?
ie; take the oxygen content for Optimax, compare it to the oxygen content for Optimax Extreme. Plus take the SG of Optimax, compare it to the SG for Optimax Extreme. Then extrapolate that calculation to the A/F ratio change.
:) cheers ;)
Edited by Sydneykid
  • 3 weeks later...
How do I do that?
A/F ratios are based on weight, not volume, hence the need for specific gravity of the fuels.
Moving on...............we have a new project car, an R33GTST that is in need of some TLC. One of the recent upgrades was a Power FC. As most people are aware, the default ignition maps are a little advanced for Optimax, Ultimate or Vortex 98. Not as bad as they used to be for 95 ron fuels, but still a tad. Obviously I will tune it properly eventually , but we have a few mods to go yet and I don’t have the time to tune it multiple times. So the idea was to stick the Power FC in and run it on the default maps for a couple of weeks. On Optimax and Ultimate (didn’t try Vortex) it was reaching knock of 60+ up our usual test hill in 4th gear as logged on the datalogit. The dash warning was also flashing frequently, as it is set for 60, in normal day to day driving around. When the tank was just about empty this week, we filled it up with Optimax Extreme (@ 5 cents a litre more than Optimax). Several runs up the hill and we are not seeing knock over 10. And zero dash warnings in 3 days of normal driving.
Now that is very worthwhile, there is not enough Optimix Extreme around yet for me to tune it exclusively for 100 ron, but it sure will be a useful for the odd track day or run down the ¼.
I will monitor the effects of the ethanol on the fuel lines, o’rings and seals over the next few weeks. The injectors and fuel pump will have to come out shortly so I will check their condition as well. I am not anticipating any problems, but it is still worth checking.
:P cheers:)
Edited by Sydneykid
Remember only about a year or two ago there was uproar around service stations selling fuel with ethanol. Cars were not running properly, there was a lot of press about it.
Yes, and that was with dodgy operators puting more than 10% ethanol in the fuels. See ethanol is/was cheaper than petrol, therefore some operators would put up to 20% in fuel. Now when you are talking those levels of ethanol it certainly isn't good for the cars. This is the situation which cofused people into thinking that any percentage of ethonal being bad. Back then, noone said that 10% ethonal was bad, they did however say that 10% was the acceptable limit.
I've been using it since the first day it came out in Sydney. On my 15th tank about now. The car feels stronger, SUPER SMOOTH adn no signs of crap in the fuel lines. It really sperates itself on those 40 deg days (especially when I don't have any CAI). Meliage is about the same but with the extra reponsiveness and strenth aI still count that s being more "efficient"
Extreme is all that is man!!!! (9/10)
BTW. Did anyone watch that craptacular report on PULP last night? The were crapping on about PULP getting teh same milieage per tank than unleaded. The way I saw it was that more power for the same KM's is the definition of efficiency! Naomi Robson sucks balls. Bring back Jana Wendt
Sam
^ but they said this is for cars turned to run on 91RON, which is fair enough.
They failed to mention imports need to run PULP, so its not just a revenue raiser for the petrol companies. Funny how they leave stuff out when its convieniant for them.
Were they using some POS econobox that doesn't have a knock sensor ot adjust timing etc? Wouldn't surprise me if they weren't, and then actually reported that PULP is bad for the engine since it causes pinging in those boat anchors.
8/10 (as posed by the original question)
My car (stock & untuned) seems to run rich - as is the factory's habit.
It ran better on 95 RON 10% Ethanol (I think thats what it is) from ... um.... independant... than it did on optimax... so...
Oh - and why does ethanol have more oxygen? COOCH (translation - go learn chemistry)
  • 1 month later...
After a month (~2,000k's) of running exclusively on Extreme in the R33GTST, I did a fuel filter change on the weekend. Cut it open and no sign of any foreign material, deteriorated fuel hose etc. That means zero effect from the 5% ethanol, as expected. So we will continue to use it.
:O cheers :(
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
