hi i am having troubles with my r33s2 gtst was eratic now getting worse
anyways starts fine drives well for a bit, then put my foot down, back firing wont rev, slowly dies, still drives well off boost. now ive tested the fuel pump, good pressure, exchanged afm ok, checked coils ok( cant see being related)
by passed boost controler ok i dont no wat to check next
do peoples tps play up?
i have an altered plenum(throttle) move to the front but has been fine for a long time
its all pretty much stock turb back exhuast, pod, fmic, std boost etc
any ideas? anyone experienced similar?
any help appriciated
https://www.sau.com.au/forums/topic/104051-trouble-shooting/
sounds like a coil or a crook ignitor champ.
I would be testing them next.
My first guess would be an air leak under boost, check all the fittings, hoses and clamps and the intercooler itself.
:P cheers :D
:P cheers :D
checked for that was the first thing i did, some cooler clamps were bit loose-tightened up, inspected all joiners for holes all ok, checked for vaccum leaks seems ok still probs
me going crazy
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
