Hey, i was just wondering what size and type is the stock
Nissan Skyline R33 GTS-T Series 1 turbo?
if anyone knows please post it up so i can compare to mine...
recently imported and been told it is a differnt size turbo so i would like to know whats what...
Also, what is the max power (BHP or KW) you can get out of stock series 1 turbo?
And what would be a genuinly perfect turbo to put on my car to either push it above 300KW or around 300KW...
Please post if you know the specifics of all questions or just one would be great... Thanks
https://www.sau.com.au/forums/topic/104065-stock-turbo-size/
Guest
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
