you have to remove the bar that holds them down from inside the boot. get into the boot remove the cover where the battery is and look up from under the parcell tray. you should see the original speaker holes. there should be a par that runs across the lenght of the speaker hole that is contected to a bolt which is connected to the speaker. it should be held in place by a wing nut remove this the bar should come off and now you should be able to remove the speaker.
mr 32
Mine were not bolted down... there was about two screws in each holding it down. They made dirty big wonky holes in the process, and the rear seats had to come out to get the boxes out.
What a nightmare... the Kenwood bit that lights up had power wire running through the boot, over the spare tyre, and tapped into the licence plate lighting!
Worst... install... ever!
Mine weren't... if they're kenwood, they won't be standard I don't think. Mine were the Kenwood surface-mount boxes, but the tweeter was cut, the mid was missing, and the woofer was replaced with Pioneer 3-way speakers. And they were half broken too. =-///
step one get a jigsaw
step two cut the shit out of the speakers (not the shelf)
step three grab pinch bar
step four bash speakers
step five remove all pieces of shitty kenwood speakers from shelf
step six buy better ones
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
