  • Replies 193
Posted Images
My #6 rod decided it would be funny to punch a hole in my block and then use the oil to set the car on fire.
Thats not funny at all..... Infact broken rod makes ross cry :)
is anything salvageable / extent of fire?
will there be a revival of bluey?
that is no good at all mate. it's the hateful thoughts of all the porsche drivers you've passed over the years I reckon. Is the car salvageable, or comepletely toasted?
Considering the size of the fire and the length of time it took to get it out (we had to use 5 fire extinguishers to get it out) there is suprisingly not that much fire damage - that we know of so far. Things like the steering rack boots and front gaurd liners are toast but otherwise it doesn't seem too bad.
So now we'll just have to pull the engine down and keep our fingers crossed that its really just #6 thats damaged and the rest is salvagable in the engine.
On way or the other the Dragon will breath again it's just a matter of when which is a matter of $$$. LOL
But I really want the car going for the NSW trip in November. I'll be gutted if I can't have the car ready for that trip.
Bugger me!! Went looking for Dutton info, thought I'd drop in here and it's all happening.
You just have to try for the win with everything Snowy. Best BBQ. Best under bonnet BBQ. Surely Roy and I didn't set the posts that high?
Jokes aside, damn sorry to hear it.
Hey Bris, for a couple of beers I "may" have some GTR32 rims with good semi-comp rubber for broad minded persontin' at Dutton. Call if you need them. Also have 17's but they have the somewhat worn wet compound so not good for long distance.
Snowy I've been keeping watch and there is the odd block, crank (in need of resize), rods and head about which would be a cheaper starting point for rebuild than a whole engine. Just hope you can salvage most of it.
well after anoth all nighter and tryign to back to back last night with no sleep, i droppred the car off the jack without putting the rins back on the front. At that point i decided i needed sleep, oh, also ran the brasker reservoir dry when bleeding brakes. Need sleep badly
4th attempt at rego today ;)
no worries big boy. hard corey can't see the fans without a fancy seat.
i hope you are nearly there mate.
snowy, that really blows mate. sounds very likely that block=gone, crank=gone, $$$=gone. ;)
Things like that really show you how important a good fire extinguisher is. after seeing how weak sauce most of the 1kg dry powder ones people use are, i now use the BFI one which put's out 4 times as much as all the others i've seen. definately put it on your buy list after the rebuild.
Anyone know what the results are? Who won?
I was just speaking to a friend of mine who was running a GTR on the weekend, ended up pulling the fastest time at Sandown. Take that Porches, Lambo's etc.
I only just got to see the QLD Dutton TV coverage yesterday. its a bit of a 'khana fest. I'd be wanting more speed events (and not 400m drags or 1000m time trials) considering the entry money!
are the ones down south the same sort of thing- lots of khanas, and the occassional race track thrown in here and there? do they close any road sections?
as someone with a background in forest rally, I think its a bit cheeky calling Dutton a "Rally"!
Its a lot of money to a guy like me. But i really enjoyed it. Woudl i do it again. Hmm i dont think so unless i somehow find myself in the position where i have had fun with my car all year and nothing needs repairing for Dutton. Its the new rotors, pads, fluids, timing belt/water pump, idler bearings, diff etc that i needed for Dutton that made it so expensive for me. I didnt even have time to fit some of the gear, and i needed the diff come the skidpan :)
Still i think i showed that i need to learn how to use a hand brake :P
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
