The Zeni Tani thing is all i know, i thought it was a Titanium turbine...i only know what i have found on the for sale adverts in overseas websites/publications and what the original owner posted on SDU years ago. Ill have a hunt around SDU tonight and see what i can see
thanks mate!
whats sdu??
  • Replies 193
Posted Images
Hey Bris,
Since you seem to know so much baout this car - how does it stack up against say Benno's or Sams?
BTW - Russ - you know about the Nov NSW excursion right? John (UAS) said he spoke to you about it and it would be awesome if you guys can make it down too.
I don tknow that much at all about the car. Liek i said only what i have seen in adverts here and there and years ago when the owner was talking about it on SDU. So dont really know how it compares to Sam or Ben's car.
Though i suspect it would be more Sams car then Bens, because of the weight of the thing...but really who knows?????
I KNOW its quicker then my car :wave:
oh and its faster than mine too! it doesnt go at all at the moment!! ;)
Neither does mine...first my car looked like this...
Then i hit something on the track...
Then a lap later the gods caught up with me when that damn cat told them who did it...
Which up close looked like this...
But JAG33 came dot my rescue...
So after fixing it i thrashed it around for while, was within a second of Snowman around Sandown the one session we did together...then parked it for a paint job which is about done.
I repeat, for the record...Sandown Sprint Session Three. The only time we have been in a Super Sprint together.
Lap 1
Bobo the Snowclown - 1:31.0100
Roy - 1:31.8900
Just warming up.
Lap 2
Bobo the Snowclown - 1:25.8500
Roy - 1:25.5800
Would have gone quicker but 1600kgs of steaming blue sh1t was blocking the track in front of me.
Lap 3
Bobo the Snowclown - 1:23.8200
Roy - Spun at Turn 4, but my Data Logger had me 0.4sec quicker then my best to that corner. I only spun because of the road block's corner speed was so slow that i almost t-boned it mid corner :D
How much power does your car have Bobo? How many times have you driven around Sandown Bobo? ... that was about my 10-11th lap in the dry.... :(
I would stop putting sh1t on my car as the fact that you are not really that much quicker then me in my POS, suggests something about someones ability to drive his finger up a dogs ass :mad:
Perhaps Bobos car is has never recovered from its stage fright either. I should mention my car isnt as pretty as yours either so dont have so many ppl willign to help push it
LOL... i miss all the smack talk on the Autosport site :laugh: Ive got nothing except personal attacks on a bloke who drivers circles around me :O
The top few inches of the guards and doors are painted gunmetal grey to match the stock colour of my car so you could either veeery carefully sand it back or paint the same section to match your car.
Just weighed them, bonnet is about 7kg (stock gtr ~10kg?), doors 17kg ea (stock ~30kg) and guards 1.2kg ea (stock gtr ~2.Xkg). That's with all electrics, hinges, handle, window, motors, speaker etc so i imagine you'd knock off a fair bit with an acrylic window.
Edited by neil_se
Just weighed them, bonnet is about 7kg (stock gtr ~10kg?), doors 17kg ea (stock ~30kg) and guards 1.2kg ea (stock gtr ~2.Xkg). That's with all electrics, hinges, handle, window, motors, etc so i imagine you'd knock off a fair bit with an acrylic window.
you have pm neil
Fire started when the heater hose into the firewall split and sprayed a mist of glycol ethanol over the glowing red exhaust housing/manifold...the stuff is flammable when in a 5% mist with atmosphere, and is preheated above 90 deg C. LOL a few things had to happen for it to ignite, if it happened a lap earlier or on the street it would have been just a coolant leak. It just happens the split was fine and the coolant temp was about 94 when it split.
I now run sheathing on the line to protect it from the heat
Ill ask what the PM is probaby about ;) How much do you want for the doors?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
