Hi all,
I just got my 2nd exhaust from SAU member,
http://www.skylinesaustralia.com/forums/in...topic=99905&hl=
can some 1 tell me wat is the pipe that look similar as a CAT?
isit a CAT?
or just a odd pipe? wat isit?
thanks,
and i am thinking of instal it myself,
wat is the tool require?
such as 6 new bolts,
wat kinda bolts to buy?
and Do i need exhaust gasket?
and wat kind of gasket?
and anything else such as silicone, and wat type?
i just wana make sure i do it right,
can some 1 please give me advices,
thank you,
cheers,
darrien
https://www.sau.com.au/forums/topic/104122-fitting-a-cat-back-exhaust/
Hey man what's up.
Ok that pipe is a test pipe NOT a cat. All it does is fill the gap left by the cat so basically you have a nice straight through system. Just be aware that you most likely won't pass any emission tests (if you have that where you are) so I'd suggest keeping your stock set up or at the very least a good stock cat.
What you need is either liquid exhaust gasket or regular metal exhaust gaskets, do not use silicone, and also hardened bolts and nuts. I'm not sure how it works in Austrailia but here in Canada the higher the number on the bolt, the stronger it is. So just get the strongest bolts you can. Also a couple of jack stands to help support the system untill it's bolted in to place and I'd suggest either a regular air impact or cordless impact gun to secure the bolts.
So that's about it, should'nt take you to long depending on how hard it is to remove your old system.
Good luck with it. :D
Take care.
Cheers B)
Thanks for the advise,
Not legal?
uh oh, :rofl:
do u really need impact gun to tighten the bolts?
can i just use man made muscle gun :lol: to tighten it?
as long as it realy tight is ok?
coz i dun have acces to air gun or impact gun.
gona get it fit this weekend, just gona need so bolts and gasket.
thanks heaps for the advices man,
cheers,
darrien
As for the test pipe not being legal, well I don't know all your laws with regards to cat's being on cars or emissions rules either. I do know here test pipe's are not allowed and with no cat, there's no way in hell a car would pass the etest.
Well you don't "have" to have an impact gun but it's the best. If you do wrench them down yourself just get it as tight as possible so you don't have any exhaust leaks. Impact guns just ensure that won't be an issue, that's all.
Other then that, ya your good to go mate. :rolleyes:
Let me know how it all works out.
Cheers B)
Edited by sidewazegtst
Thanks sidewazegtst,
I will give it a shot,
but yea, ofcoz i will have a CAT, the exhaust i got is from CAT back, for now, am retaining my stock CAT but later i will have a High flow 1.
hope its all go fine,
*finger cross*
cheers,
That's other lump is just a resonator.. meant to quiet things down a bit. I think the catback there in the photo is setup for a cat at the end...I think it is - really depends on the length.
You will need 2x 3" exhaust gaskets (get from exhaust shop).. You'll need the other for when you replace the factory cat (which is only 2 1/4" -- a restriction)
You may not require gasket goop to get a good seal (although its probably an ok idea). You will also need 4x M8 x ~50mm high tensile bolts to secure it to the Cat.. Get them from Repco, Bunnings, etc. They are a brass colour.
You don't need a rattle gun. Just a good 1/2" socket and shifter, and a spanner on the other end to hold the nut.
I fitted my fuel exhaust system myself. Takes an hour or two. Probably less if you have a friend to prop it up for you.
Exhaust fitted, nice and fitted great, simple job
Thanks for all ur helps guys.
very easy, i spray a bit of WD 40 and wait for 20 mins
after that, the bolts are easy.
took me 60 mins to drive around geting bolts and gasket,
and 45 mins to remove the old system and put in the 3 inc .
Cheers.
darrien
  • 6 years later...
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
    • As somebody who works in the energy sector and lives in a subzero climate, i'm convinced EV's will never be the bulk of our transport.  EV battery and vehicle companies over here have been going bankrupt on a weekly basis the last year.
    • With all the rust on those R32s, how can it even support all the extra weight requirements. Probably end up handling as well as a 1990s Ford Falcon Taxi.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
