If you want to sell it mate, post your location and the details here, I cbf registering on another fourm !
no offence if ur really after a car then goin to my web site shouldnt be a prob.. reason im doin this is to keep the tyer kickers at bay i dont have time for ppl who just want to look at the car and give shitty offers or tell me they they can get a GT-R for 20k the car how ever is for sale atm im in no rush to sell it if it sells it sells if not il pump more $$ into it ..car has had 2 full features and pics here and there in a few mags in fact its in this months issue of fast fours top engine bay six cyl winner 2 years in a row at jamboree 04-05
Edited by japwpn
https://www.sau.com.au/forums/topic/104140-2ownu/#findComment-1920421
  • 11 years later...
Edited by barraspalding
never knew it was dug up from the grave!
https://www.sau.com.au/forums/topic/104140-2ownu/#findComment-7855298
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
