Just trying to find out if a LSD is a standard part in the 94 manual R33's as ive read around a bit and a lot of people seem to be looking 4 them, as they say they dont have 1. Yet mine seems to have 1 already and jus trying to work out if its standard or a replacment???
Or maybe its jus been welded up as it throughs the car side ways pretty vicsiously (did i spell that right?)
Anyways not complaining as i luv it but just interested.
Cheers
https://www.sau.com.au/forums/topic/104154-question-bout-lsd-in-r33-s1-94/
turbocharged r33 gtst came with lsd standard as far as i know
ive been through 2 stock lsd centers, the one im on now is screwed, i get stuck on steep driveways with one wheel in the air spinning and the other one doing nothing. they do tend to wear out if you give them a hard life so that could be one reason why everyones lookin for them.
mechanical lsds are not a standard item and are fairly noisy so if you diff is noisy as you turn corners tightly at low speed then theres a good chance you have a mechanical lsd
quickest way to tell if your diff is a lsd is to look on the housing for an orange sticker telling you so.
Cool thanks man will check it out. As far as i can tell its not noisy when cornering tight but then again the car came with a 4" cat back exhaust and is bloody loud so maybe thats blocking it out?
Also was mucking around with a boost controller the other day and stupidly hooked it up wrong, my gauge was reading 1 and a half bar but the engine didnt fault at all, no fuel cut no backfire no audible detonation jus seemed to take it noramlly besides the bov being loud as hell and 2nd gear smoking it like it thought it was 1st. Ive read around a bit and a lot of people seem to incurr cuts at around 14psi why would this engine be any diff?? as far as i know its stock i had a chat with the people i bought it off and they jus say the engine is in good order....
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
