Hi. Am hoping someone can help me with some info on the Apexi D Jetro. I am after a wiring diagram for the map sensor wires and also the instructions on where the map sensors get plumbed in( is it to 3 and 4 or 3 and 5 cylinders .
Any help would be appreciated.
Regards
Julian
https://www.sau.com.au/forums/topic/104178-apexi-djetro/
hi julian,
http://members.dodo.com.au/paul/docs/power...powerfc-faq.htm
that may help a little, it does cover the djetro a little bit, not sure how helpful it is, let us know. its taken from the manuals basically. i have the latest djetro manual but it is in japanese
https://www.sau.com.au/forums/topic/104178-apexi-djetro/#findComment-1916914
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
