I just got a quote back from a workshop, not including labour, for the following:
Slotted Rotors x2 - $500 (no idea what they are yet)(or I can wait 2 weeks and get 2xDBA slotted rotors for $300)
Pads x2 - $135
Master Cylinder - $195
Power Steering Boot x1 - $35
Power Steering Pump - $? no price
Centre Muffler leaking, replace with straight pipe - $90
I have done brake pads before and rotors don't sound that hard to replace either. The master cylinder was reported leaaking because there was a bit of paint stripped away beneath it, it looks fine otherwise. My guess is i could save a lot on labour cost if I do this myself, right?!
cheers B)
https://www.sau.com.au/forums/topic/104195-minor-service-quote/
I hope you're not referring to the cat? Straight pipes are illegal...
Pretty much everything else you listed you should be able to do yourself.
yeah, GTR's have a second muffler, removing it adds a little bit of noise I was told (kinda obvious), but I don't know if its legal or a good idea!!
$300 total for 2 front rotors ($330 for 2 rear rotors). I don't know what the DBA rotors are, I guess your referring to the series! (ie 4000's etc..) I will try and find out today and let you know. BTW that was direct from DBA over east.
I'll also find out what the other rotors were for $500 a pair...
Well I can't say i've ever noticed a 2nd muffler on my system, then again it's not standard haha. I still have standard dumps at this stage. 3" s/steel to the cat, 3" hi flow cat (came over with the standard one lol), 3.5" s/steel cat to rear muffler....
And yeah that does sound fairly cheap for the DBA's! DBA's are fairly popular performance rotors. For a full set of replacements for r32 gtr (slotted) was going to cost me just under $700 from repco....
Edited by randominsanity73
OK, well the $300 a pair DBA's were just the standard driving brakes, I don't even think they were an x000 series. But I just got word back from Perth Brake Parts in Welshpool and they do street and racing performance DBA4000 slotted rotors, front and rear for $195ea
They also recommended Formula Feroda brake pads for the front which were $130 a pair and just a cheap brand called Lucas for the rears which were $40 a pair (or $40 each, can't remember).
So yeah, if you are after the 4000 series, which are recommended for GTR's because they are a higher grade steel , give Perth Brake Parts a call. I also found out that it was the DBA4000's from Top Racing @ $500 a pair :)
cheers B)
Tom
So yeah, if you are after the 4000 series, which are recommended for GTR's because they are a higher grade steel , give Perth Brake Parts a call. I also found out that it was the DBA4000's from Top Racing @ $500 a pair :P
cheers B)
Tom
Those bastards! I just bought a pair of ferodo formula's for the front and they charged me $150! (inc gst). The only reason I didn't quibble with it, was because I didn't have the part number to get a price from my contact that works at repco, and his system was showing 3 different part numbers all for the same year of gtr, for the same type of pads....*growls*
ah well, you can't win 'em all. :(
I am gunna head down there to pick up the gear tomorrow afternoon. They don't know this yet, but my dad called them and they have all these things in stock now. First in best dressed (or is it stops quickest :) ).
Thanks stuiE, I will get a quote from them to see how much...and N I B, the rubber in the cap is rotten :P , I ordered a new one from Nissan but how does the worn rubber indicate the BMC is buggered?
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
