  • Replies 1.5k
Posted Images
This from grandprix.com
The truth will out?
Nine years after the World Championship showdown at Jerez in 1997, the then Sauber driver Norberto Fontana has decided to tell the story of what happened to him during that highly-charged weekend. In an interview with the Argentine magazine Ol?, Fontana claims that three or four hours before the race Jean Todt visited the Sauber motorhome and told the Swiss team, which used Ferrari engines at the time, that the Saubers must block Jacques Villeneuve if they were in a position to do so in order to help Michael Schumacher win the World Championship.
Fontana said that he blocked Villeneuve for only three or four corners but that it cost the French-Canadian around three seconds. In the end Villeneuve challenged Schumacher for the lead and the two cars collided. Schumacher went off into a gravel trap and was unable to rejoin. Villeneuve won the World Championship and Michael Schumacher was later punished for deliberately driving Villeneuve off the track.
Fontana said that the action had hurt his career but that Todt and Schumacher never thanked him for what he had done. To view what happened you can go to: Video and make up your own mind.
While this is all ancient history now, there is a certain irony in that after the same race there were claims that Williams and McLaren colluded to rig the result of the race. That claim was rejected by the FIA World Council although it was never clear why the allegations ever got as far as the World Council.
The last teat at silverstone was quite interesting. Piquet jr topped the sheets first time out!! Hamilton... not so much. I really really hope that he doesnt get that remaining seat, theres people that have been around longer and deserve it more.
Silverstone - Great Britain 20 September 2006
1 N. Piquet jr. Renault 01:19.565 73
2 H. Kovalainen Renault 01:19.700 119
3 P. de la Rosa McLaren 01:19.921 110
4 F. Montagny Toyota 01:20.616 87
5 A. Wurz Williams 01:20.822 68
6 L. Hamilton McLaren 01:20.864 64
7 R. Schumacher Toyota 01:21.130 55
8 T. Sato Super Aguri 01:21.981 39
9 R. Quintarelli Spyker MF1 01:23.206 84
10 N. Karthikeyan Williams 01:24.031 39
11 S. Yamamoto Super Aguri 01:24.839 26
Hamilton has big raps on him, but how do you rate Nelson's young-un?
higher than Hamilton... Nelson seems better for some reson. I watched a couple GP2 races and i just get that good vibe from Nelson. More natural ability is all i can come up with, he seems to adapt to changes very quickly. And he seems to be fast no matter what you stick him in
oi.....lay off super-aguri bastard.
I never got my shirt >_<
i'll tell you a funny thing about Super Aguri merchandise. I was looking for some the other day, and came across a singed photo of Sato in a Super Aguri (may have been Ide actually). You know these things, a nice photo of the car pounding the curb, or taking the flag with the drivers signature over it. Well this one was a photo of a super aguri bouncing across the gravel trap!!! and personally signed by the driver. how golden is that. I should have bought it.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
