  • Replies 1.5k
Posted Images
For those of you that care here's wat happened in qualy
btw.... live timing is jerkoff-able
1 G. Fisichella Renault 1:33.840
2 J. Button Honda 1:33.986
3 N. Rosberg Williams 1:35.105
4 M. Schumacher Ferrari 1:35.010
5 M. Webber Williams 1:35.252
6 JP. Montoya McLaren 1:34.536
7 K. Räikkönen McLaren 1:34.667
8 F. Alonso Renault 1:35.514
9 C. Klien Red Bull 1:35.171
10 R. Schumacher Toyota no time
11 D. Coulthard Red Bull 1:34.614
12 R. Barrichello Honda 1:34.683
13 J. Trulli Toyota 1:34.070
14 J. Villeneuve BMW 1:34.752
15 N. Heidfeld BMW 1:34.783
16 F. Massa Ferrari no time
17 S. Speed Scuderia Toro Rosso 1:36.297
18 V. Liuzzi Scuderia Toro Rosso 1:36.581
19 C. Albers Midland F1 1:37.426
20 T. Monteiro Midland F1 1:37.819
21 T. Sato Super Aguri 1:39.011
22 Y. Ide Super Aguri 1:40.720
Edited by ctjet
Agreed, live timing is sex.
If Webber was able to get a few more laps in with those new tyres at the end he could have ended up on the first row.
No one was near him for the first half of the session, he did well to bank that nice lap.
oh and i didnt mention that "Fisico" looks good for a win, not that im cheering for him or anything but he kept on pumpin in the fast ones with no probs
and wat happened to Alonso???
SMWBH syndrome.
Lets hope Webber gets a podium, Williams/Cosworth combo looking ok at the moment hopefully they can keep it up.
Rosberg has certainly impressed.....so far.
what the??? Nico>>>> P3 (not bad for a newbie!!!) glad to see Alonso at P8-might get interesting if he starts to come through the pack. I'm betting Fisi doesnt last long at the front-hmmm could be an interesting race with this jumbled grid.
well the race was good for the first 20 laps, then it was a bit of a snooze fest.
it was nice to see webber not taking any crap from rosberg at turn 1. but they both got hung out to dry a bit. I dont think there was any great need for rosberg to squeeze webber so far off line as webber was always going to come up the inside, rosberg should have been more concerned with the rest of them (gonzo in particular).
shame the cossies blew, but 2 fresh engines for melbourne means i will get to hear a V8 at 21 000rpm in qualifying. :dry:
I'm glad Kimi got shunted-it will make it interesting later in the season when he tries to regain some points.
Yep fresh cossies for the boys in Melbourne-love to see the williams on P1 P2
Edited by overev1
Rookie mistake from Rosberg.He should have realised Webber was going though and just tried to stop Alonso.He ruined Webbers and his own chance to shine up front before their motors went.
Montoya wasnt that quick and hardly seen him,but Raikkenon would have been fast i think as always.But its starting to look like the Renaults are gona run away with it again.
I reckon Nico will get is arse kicked for the turn 1 move.
Far too busy trying to squeeze his teammate right to the inside, there is no excuse for allowing someone around the outside
absolutely. like i said above he was far too concerned with keeping webber behind him when he should have been thinking about a fast starting, fuel heavy renault. because had he and webber kept alonso behind i doubt alonso would have been able to pass them with the amount of fuel he was carrying. it was a dumb move by rosberg and nearly ended badly. he is so quick though and will definately keep webber on his toes.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
