  • Replies 1.5k
Posted Images
Well if he is anything like his old man he will have the thing in the wall at turn one.
Team Willie must be looking good for 07. Two test drivers with bags of cash (What you mean they aren't there on talent alone?), Patrick is making a bit of a comeback, new Toyota motor, new naming rights sponsor. Just hope the drivers are up to it.....
He wont have a chance cause that williams piece of sht will break down before turn 1
heres a little taste of what its all about...
Estoril 92 Press Conference
ahh the good old days
:thumbsup: :sorcerer:
It is amazing how narrowly F1 drivers define what is for the good of the sport. Senna kept Derek Warwick out of a Lotus drive in '85. Lotus signed Johnny Dumphries instead. But he didn't like it one bit when Prost did the same to him at Williams. Mansell shot himself in the foot with his ridiculous demands on Frank Williams & to be honest Frank didn't really nead him anymore, let alone at the price Mansell was asking...
Davidson joins Sato at Super Aguri
finally... another Brit that itv wont shut up about
but seriously he's very good, and if he can prform on a sunday like he does on friday he should punish and expose Sato for the shit kicker he really is
Mind you, Sato is one of the highest paid drivers on the grid now, supposedly raking over $10mil per year, with Davidson only getting $250,000
wasnt it davidson? i understand your point, but i still think in time Ant will get the better of Sato on a regular basis... but my point was that Sato made more than Alonso last year...
Considering the vast chasm of diving ability between the two it made me sick to read that... it all changes next year tho, Alonso will be on 20mil +
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
