Hey guys, got my cooler fitted, got a type m front getting resprayed as i speak, and cut the opening of the bar for more air into the cooler.
My question is should i have my bumper meshed up or not?, how many on this board have meshed theirs up???, and should it be done, i knw it looks cooler w/o the mesh, but will meshing help save my cooler in the long run??
Edited by nsta
https://www.sau.com.au/forums/topic/104242-to-mesh-or-not-to-mesh-cooler/
  • Replies 44
Posted Images
Mesh will stop stuff like decent sized gravel flicking up and putting a hole in the cooler..that has to be a good thing!!
If you care about your cooler then mesh it. If you want to show the world your bling cooler, then leave it off. Personally for my 10 cents worth - go with the mesh.
if you put the mesh on you will probably take it off in a few months, and vice versa. hahah thats what im like.
seriously though, there are some big bugs round Australia and they eventually find a way to bend every bloody fin, and the last thing that goes through their mind right before they hit that cooler is...... their ass
hahah, nice thoughts, i'll see how i go tommorow wen car is back, somehow i got the feeling im going to be taking the mesh off right away!!! thanks
Can you post pics when your done? I wanna see what a Type M bar looks like with a centre bit cut out.
Cheers,
Setting aside the 'wank' factor of having mesh....I've done heaps of interstate driving as well as some fairly spirited country road cruises/drives and my mesh has saved the coolers from heaps of rocks & bugs etc. All you need to look at is the state of the mesh now with bent bits etc etc.
So I'd say it depends on what kind of driving you intend to do....
if you ever plan to drive fast on the freeway, or do to a race track you should mesh. having had the GTR (no mesh) out on the track a number of times i can tell you the cooler looks much worse for wear than it did a year ago. i have now bought the stock GTR mesh for it and one day will whack it on.
    • Man, I hope this one gets finished  i just randomly remembered it the other day and thought I’d check in.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
