I heard them in floreat last night too..
however i think i hold the answer
there was a festivle of perth finale thing down near the bell tower, was on last night and tomorrow, i think thats the bastard who had me wondering if they where practice bombing at cottesloe..
https://www.sau.com.au/forums/topic/10425-fireworks/#findComment-166828
yeah next door to me is always setting them off - it was sad cause our dog was beaten as a pup to try to make her viscious (doberman) and anything like thunder or fireworks she get so frightened she wets herself and tries to escape thru the bars of the pool fencing and often gets stuck half thru.
I appreciate fireworks but unfortuately rarely get to enjoy them cos trying to calm dog down!!!!
https://www.sau.com.au/forums/topic/10425-fireworks/#findComment-167495
Guest GR33DyMANGO
Originally posted by Steve-SST
A Helicopter was  looking around My shop in Welshpool
just after it finished , Might have been the Screamin GTRs
we were drivin Around  in last nite A J'ash - no antie
lag thou,so it may be Saddam s WOMD
The sound of Quick GTRs on a quiet nite COOLLLLLL!
hey bro... yer that was quite a show! i couldnt believe my eyes? last night i was in car lovers heaven:D
ciao
justin
https://www.sau.com.au/forums/topic/10425-fireworks/#findComment-167726
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
