Originally posted by Nizmo
yeah next door to me is always setting them off - it was sad cause our dog was beaten as a pup to try to make her viscious (doberman) and anything like thunder or fireworks she get so frightened she wets herself and tries to escape thru the bars of the pool fencing and often gets stuck half thru.
I appreciate fireworks but unfortuately rarely get to enjoy them cos trying to calm dog down!!!!
Nizmo the vet sold me some pills for ours it would knock the screens of the house trying to get in during thunder stormss you just give it to them a few hours before and they dont get upset by them-- she also said to turn the stereo/tv up full if they r inside and that works well too
https://www.sau.com.au/forums/topic/10425-fireworks/page/2/#findComment-169795
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
