32 tail lights gun metal grey L & R perfect condition SOLD
32 GTR front indicators L & R orange perfect SOLD
32 GTR Bonnet (Gun metal grey) SOLD
32 GTR ABS SOLD
32 glove box $30
32 GTR rear spoiler $175
32 GTR standard cooler piping SOLD
32 GTR speedo cluster $145
32 GTR centre guages $90
32 sun visors $35 pr
32 GTR windscreen wipers $30 pr
32 GTR windscreen wiper motor $40
32 GTR windscreen washer bottle with two motors $40
HKS air filters(2) with attachments that have sensors(suit GTR) SOLD
32 driver side electric window control SOLD
32 GTR oil catch can SOLD
32 GTR engine bay fuse cover $10
32 plastic piece that sits under the steering wheel, with driver side a/c vent $40
pm me for more details
located in sydney
parts not needed
for pics please send email ([email protected])
REASONABLE OFFERS WILL NOT BE REFUSED
Edited by DANSR33
https://www.sau.com.au/forums/topic/104275-cheap-r32-bits-and-pieces/
  • Replies 53
can you send a pic of the centre gauges i am interested...my email. is [email protected]
Ill try and get a pic to you soon, cameras dead....
u got the centre and passenger aircon vents by any chance? also any1 know of sum1 who mite wana sell a gtr grill?
Sorry mate but no and no
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
