On a whim we decided to build an RB30 and install it in my R32 on the weekend.. a rundown of what we used:
- a prepped block, forged pistons (wisecos I think), rings and 25DE head that had done 5000km in another car.
- standard crank and standard rods out of a quokka special RB30
- 25DE intake manifold
- standard 25DE cams
- 25DE rocker covers
- swapped the exhaust manifold/turbo, fuel rail/injectors etc off the RB20
- New OEM headgasket and a few other little new things from Nissan (oil pickup o-ring etc)
- NDC mains and bigends
- RB25 s1 turbo that I had on the RB20
Block had already gone through a twincam conversion so was drilled/tapped for tensioners etc. We used all the sensors etc off the RB20 and it is currently running on the groupbuy remap from CEF1E.
Bonnet doesn't close properly so I need to sort out the pipework (hitting on the bov and the cooler pipe over the fan) and it could really do with a tune.. got it booked in for the 30th but need to get a z32 afm and some injectors before then :(
What a big weekend that was!! (even had the manson concert thrown in on saturday night!) :P
Will update once tuned :D
Well, after a long wait, I FINALLY got my RB30DET going :P
Stock bottom end, no idea of kms... Was out of an auto VL though.
RB25DET oil pump
R32 RB25DE head with upgraded valve springs (around 70 pounds seating pressure)
GTR injectors
Z32 AFM
Bosch 040
Cheap FMIC
3" turbo back exhaust (HKS muffler)
RB25 turbo + VG30 rear housing
Remapped RB20 ECU
Makes 206rwkw at 10psi
RB30DET (black) vs. RB20DET with GCG highflow (red)
Edited by salad
Got my RB30DET powered Silvia on the dyno finally! Just to get it all running and so I can drive it etc before the power run.
Making 250hp, 290ft/lbs on 10psi, this is not revving it over 5k rpm also. So it's going to be making some nice numbers when I open it up, can't wait :P
Edited by GTR-Ben
  • 3 weeks later...
RB20 w/ 25 turbo
(ignore the red line in the above graph, that's when we tried 14psi untuned but it started to ping up high)
RB30 w/ 25 turbo
Only difference between the two engines apart from the extra litre are the 550cc injectors and z32 afm (and a minor tune).
Edited by bubba
  • 4 weeks later...
Thought I would put myn up, built this myself as probably alot of you have.
r32 gtr with no 4wd.
rebuilt 30
r33 rb25de non turbo pistons (10:1 comp 195psi/cylinder)
standard 26 head rebuilt
standard gtr turbos
nismo 555cc inj
standard afms
apexi power-fc
nismo lightned flywheel
26 oil pump with no restrictors
3.5 magnaflow exhaust with standard dumps
203rwkw @ 8psi.
Edited by James_03
  • 4 weeks later...
AH RIGHT SECTION NOW, SORRY GUYS.
well guys mine went on the dyno as promised. here,s a you tube link, takes a while to load, done by the racing line where i had it mapped..
car ran brilliantly all morning till 1pm. did 20+ dyno runs , final run was @ 2.17 bar 652bhp@the fly 660lbs torque @ 5500rpm
went for dinner and unfortunately left the ign on. when we returned for some light on road mapping car is now knacked beyond a joke,,
change the ecu,cam sensor, ign amp, splitfires,plugs no joy.. wont rev and on the fuel map it stays the same but when you rev it up, and return to same piont on the map that had an afr of 13 now it reads 21? numbers are the same but afr has changed on its own?. lambda,s are turned off so not them. we puit some 4 bar map sensors on wonder if they have burned out?. will start again monday..bernie
my clip
http://s212.photobucket.com/albums/cc220/r...nt=rb30dyno.flv
Edited by rockabilly
Rb25/30 (no VVT) in a VL Turbo
Eagle H Beam Rods,
Wiseco Pistons
Moly Rings
ARP Headbolts and a metal head gasket
Standard 25DET Series 1 head(recoed)
Standard Injectors(98% duty cycle) and Plenum
Garrett 35/40
074?(I think) rear housing (cars in the shop for upgrade of fuel system)
44mm Tial Wastegate Running 11psi spring
Standard VL Turbo Fuel pump and system
Haltech E6X computer
600x300x75 Front Mount
Tuned to 11psi made 356.5 Rwhp or 265.84 rwkw.
  • 4 weeks later...
RB26/30
Stock block
Stock crank
Stock cradle
Stock used mains bolts
Forged pistons
H beam rods
RIPS 26 head
T51r
R.I.P.S plenim with 90mm TB
661rwkw (890whp) 28psi spinning the tyres on roller dyno.
Ran 9.06 152mph on fully treaded wet weather suitable street tyres (Not dot drag tyre)
And 9.1 with a big wheelstand
Here's a recent 25/30 conversion.
  • RB30 bottom end
  • Spool Rods
  • Wiseco pistons 9:1
  • ACL race series bearings
  • crank collar, RB25 pump
  • Cometic 1.3mm gasket
  • head ported, std valves
  • vvt removed, Tomei 256 intake cam, HKS 264 exhaust cam
  • fabricated exh manifold, GT35/40 .7 front, .82 rear
  • front facing plenum, std TB
Engine is on boost by 3000, very driveable.
  • 3 weeks later...
I have decided to stick with stock ECU to see what it is capable of before going to aftermarket...Now if you look at the Nissan Consult data you will see I am right on the limit of the ECU and injectors.
Engine is RB25DET head with VCT connected. Head is stock
RB30 Bottom end with 8.3:1 CP pistons and REV rods.
Turbo is Garret GT3076R on HKS cast low mount manifold. 0.82 exhaust housing
Intake
HKS POD
Trust 600x300x76 F. IC
Exhaust
is 3.5" turbo to CAT and 3" for the rest.
Wastegate is HKS 60mm with 2 1/4" screamer pipe with muffler fitted (yes with its own muffler) Detail is posted in other threads
Engine management is stock. Read my other posts for more detail on how I deal with airflow cut...
NOTE that the ignition was breaking down due to too much plug gap (gap set at 1mm)...You can see this in Dyno charts.
Power_and_AFR.pdf
Power_and_boost.pdf
data_scan_277rwkW_run.pdf
RB30DET - 560rwhp on 23psi
Makes full boost at 4000 rpm - very streetable.
SPOOL RB30 rods
ACL RB30ET pistons
R34 NEO Head
HKS 272/9.35 CAM
Garret T04Z
6 boost manifold
3.5 exhaust and cat
Apexi POwer FC and Q45 AFM
This is a total street car running pump 98 fuel, std tailshaft, std diff, runs a cat, and air con.
Edited by Spoolup
R32 Gtst RB2530 with VVT
VL block with line tapped in for VVT
Stock RB25det head
Forged pistons
Stock exhaust manifold
3" exhaust
Greddy inlet plenum
Tomei fuel pump
Stock injectors
.63 exhaust internal gate (T04E) turbo
RB20 ECU+SAFCII
600x300x50 FMIC
25 gearbox + HD clutch
270rwhp@15psi
Torque monster pulls from 60kph in fourth, nice off boost reponse.
550rwkw 740rwhp 3300nm wheels 805nm engine 24lb boost 100ron (maxed dyno had to bring boost only slowly for hp figure)
26 - apexi mild cams, kelford valve springs hpe full radious valve grind and port,
jun intake 900mm throttle 900cc inj link lem g3 tuned by phil at nzefi
stoked crank 87.8mm 87mm hks pistons carrillo h beams, clealite 77 bearings, acl race mains, std head and cradle bolts, acl 3 layer gasket.. 9.8:1 static 9:1 dynamic?
t78 33d 15cm turbo 24lb 690rwhp at 19lb
drift up..
  • 1 month later...
May as well post up here, graphs show run-in tune. Will post up again once full tune is complete, may be a few more months though.
Just posting the comparison between my previous rb25 set-up to the new rb30 set-up. First is a power comparison and second is a torque comparison. Can't wait till the full tune :whistling:
Hey guys, finally got mine tuned tonight. Numbers were smaller than i originally hoped but were sacrificed for mid range power, response, driveability & durability. Absolutly LOVE the way it drives
Many mods including
Rb30 block/25 head with vct & oil restrictions to head thanx to SK info
Port & polished head
Tomei Cams & Springs
JJR Adjustable exhuast cam gear
Cp Pistons
Spool Rods
ACl Bearings & ARP studs/bolts throughout
Cosmetic Head Gasket
Gt3540 .82a/r
Tial 44mm external gate
3" Titanium Exhuast
6 Boost exhuast manifold
Plenum chamber inc 103mm T.B
N1 Fuel pressure Reg
N1 Oil Pump
trust Oil cooler
Custom catch can
Crank Collar
Monkey Wearhouse FMIC
Haltech E11v2
Sard 850cc injectors
Splitfire coils
Malbro lift pump
Bosch 040 fuel pump at surge tank under car
GFB plumb back bov
& more less interesting parts
For Those of you who are good at reading dyno sheets the two spots where you can see pinging were fixed since this run.
1993 R32 Gts4
Fully stripped as in no longer a road car.
Fibreglass bonnet, front gaurds, boot, bumpers, sideskirts.
RB26/30
Stock RB30 block and cradle
ACL pistons
H beam rods
hks metal head gasket and head bolts
rb26head
hks step 2 cams
hks adjustable cam gears
wasted spark ignition system
hks f con v pro
single garrett 3582
external wastegate 44 ml tial
26 oil pump
n1 water pump
hks valve springs retainers
gtr intake
740cc top feed injectors
map sensored
FMIC
3 inch intake
3 inch exhaust from turbo to bumper, straight pipe.
oil cooler
gts4 sump pickup
gts 4 auto box control wires clipped.
aftermarket torque converter. stall 2250rpm
ABS, brembo disc's calipers dot 5 fluid.
center diff torque splitter 50/50 100/0 or on/off. lol
D2 adjustable platform suspension.
401 hp 4wd 388 ftpnd 4wd @8 psi on race fuel
peak torque reached top of second peak hp 3rd, overdrive off.
$$$$$ i never want to add it up.
Edited by nizmonut
  • 1 month later...
A day in the life of a big power skyline
4am open shed coffee
4 15 another coffee
430 unblot 3582r and manifolds
5am more coffee
510 bolt on new manifold and T51R kai
6am plug in laptop make sure car runs
615 jack up trailer take two flat tyres to tyre shop
745 put wheels back on trailer load car
8am stop at air strip to pick up 80 litres of av gas,
ring gary to confirm i have dyno for the day
820 stop at gas station fill up rodeo,
945 arrive at workshop
10am unload gts4 put front bar back on.
1015 quick road test to warm up car
1025 everyone climbs under car looking for oil leak,
oil return line leaking 5 hose clamps au't ta do it
1040 strap car on dyno hands wont stop shaking need more coffee.
1050 first run, engine leaning out with new turbo injectors at full duty 18psi
11am change injectors from 740cc to 1000cc sard's
1130 2nd dyno run, alter injector pulse and check a/fr's temp oil pressure fuel pressure all ok
injectors at 54% duty
1150 3rd go, car starts breaking traction at 21 psi 3rd gear, four of us sit in the boot with one on each door sill...power 690 @ all four but nowhere near what i want.
1215 have lunch and sit down chat about the issue of traction and non eventful lower than expected run
1pm gary try's different approch tinkering with timing and loading up the fuel working his magic with the hks f con pro. manifold glows white hot engine takes on whole new angry engine note, everybody grins with expectation.
1440 5th dyno run engine pulls hard the shrill whine of the t51 filling the workshop @ 27psi, smoke starts pouring of the back tyres, everyone piles onto the car, the revs drop and then start to climb again 650,680, 710, 750, 780, 800, 815, 840, tyres start spinning again, gary drops his tools and jumps on the back while craig looks accross at me hanging out the passengers door ,860 870 881 poof! gasket blows, craig
buttons off but we all grin, gary comes up to me pulls the ear muffs off and says not bad for a bits'a.....
im happy the screen blinking at 881.77 and 775.01 consecutivley
In a 180sx
Rb30det
R32 rb25de head, reconditioned
Block all acid diped
replaced pistons and rings
acl bearings
3inch exhaust
Intercooler
Evo yellowtop injectors
cheap t3/t04e .63 rear .50 front
link g3
hd clutch
crap photo, but 240kw at wheels at about 5250. Full boost around 3400. very linear power. 23062008pk5.jpg
Edited by trunk-rattlin
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
