rb2530
tomei 260 8.8mm cams
gt3582 turbo with tial.82 rear housing
tial 44mm waistgate
my homemade lowmount steampipe manifold & 3' exhaust
greddy intake plenum/factory throttle body
link g4 ecu
ID1000 injectors
splitfire coilpacks
2x 044 pumps
600x300x100 cooler
352.8kw @ 17psi
  • 3 weeks later...
Small update.
Not sure what the issue is, combination of cam timing too far and something else we are yet to find.
Lots of torque, great to drive, but clearly falling over very quickly.
Easy fix- all in the cam timing ;)
Now running 20psi, plenty left in it. This is beautiful to drive on the street. this with a 200cell cat in place too!
Edited by Simonster
My RB30/26 build
HEAD WORK
mild port n polish
1mm oversized valves(brian crower)
springs and retainers(brian crower)
resufaced the head
272 with 10.55 lift cams(kelford)
BLOCK WORK
mahle pistons 8.5 comp
spool rods
fully balanced
oil drive collar
N1 oil n water pumps
deck block
borg warner s372 turbo .84 exh
1600cc injectors
dual -6 fuel lines from walbro's 400lph
running on e85
okada coil packs
Mercury Motorsport custom design rb26/30
RB30/26 "3064cc"
nitto oil pump
CP Pistons
SPOOL Rods
ARP main studs
ARP head Studs
Modified bearing caps
Lightened and balanced crank
Oil Cooler
ATI 1000hp harmonic balancer
S13 Power Steering pump
Nismo engine mounts
PWR oil cooler
PWR power steering cooler
Hypertune 90mm Inlet Manifold and Throttle Body
6 x 1000cc Inj's
Hypertune Fuel Rail
600x300x100mm ARE intercooler
walbro intake fuel pump
twin bosch 044 external fuel pumps plus 2 liter surge tank
6Boost Manifold
Turbo smart Gate
Garret GTX42r turbo
4inch dump, 3.5icnh after the diff and a 4 inch muffler Exhaust system
Exedy twin plate clutch - 1000hp rated
PAR gearbox 1st thru 5th
Standard Tailshaft
35psi 8000rpm limiter eflex fuel
550kw
standard rb26 head and standard rb26 cams
  • Like 1
  • 3 weeks later...
RB30/25DET
NITTO Forged internals
NITTO 1.2mm Drag headgasket
ARP Main studs
ARP Head studs
Nismo Engine mounts
9.5L ASR sump
Moroso external oil pump
ROSS Harmonic balancer with pump drive kit
Ported head
HKS 256/264 cams
Greddy Plenum
Speedfab Exhaust manifold
Twin TIAL 36mm Wastegates
HKS T51R KAI turbo
4inch Custom turbo back exhaust
100mm Intercooler
2000cc ID/Bosch Injectors
SX Fuel reg
Twin entry fuel rail
2x Bosch 044 Fuel pumps
Nismo Intank Fuel pump
E85 Fuel
Standard RB25DET gearbox
JB Single plate Full Monty clutch
Tomei Trax 2 way LSD
Supporting mods etc etc etc
547rwkw@25psi
  • Like 3
Nissan Silvia S15
Full Backyard Conversion RB26/30DETT
Block honed bored and fully forged. 8.1:1 Compression
Extended Crank collar fitted, ARP bolts/studs throughout
Nitto Oil Pump, oil restrictors fitted, head oil drain.
Nismo Water Pump, thermostat and oversized R32 GTR radiator
HKS 2530's with braided lines
HKS Cam Gears and 264 Cams, Tomei cap studs
Trust/Greddy Suction kit
Fuel lines, billet rail and 1350cc injectors
Haltech Platinum Sport 2000 inc. 3 Bar Map Sensor, Boost Controller, Dual Wideband 02 Sensors
Upgraded 100x300x600mm intercooler
LS1 coil packs
twin 3" into 3.5" straight through exhaust
Heavy Duty clutch, Flywheel, Nismo slave, Pivot and braided lines
R33 RB25 Gtst gearbox Custom 3" Tail shaft.
not to sure about the diff at the moment but i think it is a stock JDM S15 3.692 ratio
Made 377.7rwkw safe run in tune. will upload Dyno tonight
r33 gtst
mods are built engine rb25/30 with neo head cr 8.5:1
cams are 270 9.11mm
garrett gt3788 0.89 exhaust housing
turbosmart hypergate 45mm wastegate
haltech platinum pro plug in
PE 850cc injectors
nismo adj fuel reg
044 external/surge tank, 2x walbro internal pumps
3.5 catback, 3 inch dump, no cat
trust intercooler 600x300x76mm thick
320rwkw @19psi
power is a bit lower than some on here not sure why really :( would like to hit 350ish :) with these mods
stock rb25 head, no vct
rebuilt rb30 block with mahle forged pistons and the usual pump drive upgrade driving stock oil pump
ross balancer
trust low mount exhaust manifold
3" straight through exhaust
38mm tial gate
gt3076r 56t turbo
2.5" intercooler piping with 560x380x75 custom return flow intercooler
stock intake manifold with stock throttle bored to 60mm
bosch 680cc injectors, 044 fuel pump with adjustable reg.
microguess ecu running six bosch coils
want to change ecu and put 3.5" exhaust on next
Edited by Dobz
  • 1 month later...
results are in.
Blue us RB30 orange is rb25. full comparison and nothing else has changed except the bottom end.
turbo is 3076 56t with 0.63 rear... falls over pretty hard and adding more boost doesnt increase it.. so rear is a restriction thats for sure. Need a .82 rear for it.
88 series 2 vl Calais rb30et (I no not a skyline but still the rb30....)
Original turbo block
No cam or piston work
Garret t3
660cc injectors
Internal and external Bosch fuel pumps
Boost actuator ( can't remember the poundage)
Bigger fuel rail
Microtech ecu
High flow cat
2.5" exhaust cat back
13psi
230rwkw @168kms
479 nm @ 135kms
Sorry again not a skyline
post-82941-0-66739000-1344249886_thumb.jpg1995 Series2 R33 GTSt.
RB25/30
Flat top CP pistons
Forged Precision H beam rods
Polished standard size RB30 crank
Stock 25 oil pump, 1.5mm restrictor, wide op drive
Stock 25 vvt head, removed ex humps and intake cleaned up. No vvt.
6boost mani
50mm Turbosmart wg with 17psi springs plumbed into front pipe near cat
GT3582r
3 inch front pipe, gutted stock cat, kakemoto catback.
600x300x100 bar and plate ic with 2.5 ic piping.
Stock recirc valve with grub screw
910cc at 3 bar JECS sidefeed inj in stock rail with stock reg
Walbro intank
Haltech e11v2
HKS twin plate clutch
Made 400rwhp (298rwkw) at 19 psi and 415rwhp (309rwkw) at 22 psi. Made 400rwhp by 4800rpm. Didn't bother turning it up more due to the stock head internals and restrictive air filter and exhaust. Full boost at about 3500rpm.
The air filter was almost sucking itself inside out. The cat and catback are probably a restriction too but in saying that the car is very quiet.
It is what it is. I'm not happy yet so better results yet to come ;)
Edited by Room42
  • 1 month later...
RB30/25DET
9.5:1 CR
Standard RB30 Crank
Forged / Balanced
Tomei Oil Pump
Oversized custom Sump
Solid Conversion To Head
Custom Cams
Oversized Valves
Ported / Polished
1/2 Inch Head studs
Nitto head gasket
greddy intake manifold
6 Boost Manifold Divided T4
GTX35R ATP 1.06 Exhaust housing Divided
Twin tial Wastegates
4 Inch Exhaust
2x Bosch 044's
ID1000cc Injectors
$100 EBAY INTERCOOLER :thumbsup:
RB25DET gearbox
NPC custom clutch
on 24psi Eflex (caltex flex Fuel)
Edited by BMYHOE
Nissan S15 Silvia
RB30 stock bore size / milled to achieve 8.8:1cr
Wiseco pistons
Steel rods
crank collar fitted/crank balanced
Tomei head gasket
ARP RB25 head studs
stock head
stock (machined) exhaust manifolds
1st round, about 1.2 bar, R34 elbows, greddy downpipe, R34 stock catalic converter, 3" Fujitsubo catback (60mm backbox inner diameter):
2nd run, about 1.3bar boost, exhaust changed to a 3.5" one that came off an MK4, but still with some 3" restrictions, downpipe modded to fit a 100cpi catalic converter (boost reading on printout is wrong, measured at wastegates):
3rd run, still on HKS GT2530´s, but now with about 1.35 bar boost and fully custom 3" elbows + downpipe:
Now with different custom intake piping and GTX2860R´s on about 1.7-1.8 bar boost (and obviously a bit less ignition and not yet optimised A/F ratios) - we usually ran the car at 1.5 bar, just tried it once on the dyno with more boost (and were disappointed by all the results that day):
  • 4 weeks later...
So, car finally got mapped but it looks like stock fuel lines give too much backpressure - so 1.7 bar was the save limit before mixture leaned out, which disappointed me a bit.
We still could get much more power out of the car, by adding about 10 degree of ignition timing - no wonder we made such poor results the last time ;-)
Edited by AndyStuttgart
  • 2 months later...
  • 4 months later...
owner built 30/25 w/vct
Fully built motor
Tomei Poncams
1000cc bosch inj
Precision BB 6262
6Boost ex mani
Plazmaman Plenum
Power FC
etc etc.. with street legal cat
Pump fuel BP98
431hp atw@ 16psi first safe tune on second motor.
  • Like 1
  • 1 month later...
Nissan Stagea 1996 AWD
Stock RB30 block apart from new rings, bearings, big end bolts, Tomei sump baffle kit and N1 oil pump. Stock R33 head cleaned up, VCT connected, Tomei head gasket and adjustable ex cam gear. Sinco Customs exhaust manifold, GT3540R turbo with .63 ex, Synapse 50mm W/G, Venom 5in 100 cell cat, 3in exhaust with straight through resonator and cannon. Hybrid FMIC, Greddy copy FFP, HKS Sequential BOV, Deatschwerks 550 injectors, stock throttle body, fpr and rail. Walbro in tank fuel pump and Bosch 044 from surge tank. Link G4 ecu. 98 Pump gas.
Plan to install some better plugs, fine tune W/G and retune for a few more KW but will probably leave it at that as I don't want to push too hard on a stock unbalanced bottom end.
Credits: Joe (Joes Mechanical) Glenn (GDS motorsport) and Soichi (ST Hi-Tec).
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
