rb2530
tomei 260 8.8mm cams
gt3582 turbo with tial.82 rear housing
tial 44mm waistgate
my homemade lowmount steampipe manifold & 3' exhaust
greddy intake plenum/factory throttle body
link g4 ecu
ID1000 injectors
splitfire coilpacks
2x 044 pumps
600x300x100 cooler
352.8kw @ 17psi
  • 3 weeks later...
Small update.
Not sure what the issue is, combination of cam timing too far and something else we are yet to find.
Lots of torque, great to drive, but clearly falling over very quickly.
Easy fix- all in the cam timing ;)
Now running 20psi, plenty left in it. This is beautiful to drive on the street. this with a 200cell cat in place too!
Edited by Simonster
My RB30/26 build
HEAD WORK
mild port n polish
1mm oversized valves(brian crower)
springs and retainers(brian crower)
resufaced the head
272 with 10.55 lift cams(kelford)
BLOCK WORK
mahle pistons 8.5 comp
spool rods
fully balanced
oil drive collar
N1 oil n water pumps
deck block
borg warner s372 turbo .84 exh
1600cc injectors
dual -6 fuel lines from walbro's 400lph
running on e85
okada coil packs
Mercury Motorsport custom design rb26/30
RB30/26 "3064cc"
nitto oil pump
CP Pistons
SPOOL Rods
ARP main studs
ARP head Studs
Modified bearing caps
Lightened and balanced crank
Oil Cooler
ATI 1000hp harmonic balancer
S13 Power Steering pump
Nismo engine mounts
PWR oil cooler
PWR power steering cooler
Hypertune 90mm Inlet Manifold and Throttle Body
6 x 1000cc Inj's
Hypertune Fuel Rail
600x300x100mm ARE intercooler
walbro intake fuel pump
twin bosch 044 external fuel pumps plus 2 liter surge tank
6Boost Manifold
Turbo smart Gate
Garret GTX42r turbo
4inch dump, 3.5icnh after the diff and a 4 inch muffler Exhaust system
Exedy twin plate clutch - 1000hp rated
PAR gearbox 1st thru 5th
Standard Tailshaft
35psi 8000rpm limiter eflex fuel
550kw
standard rb26 head and standard rb26 cams
  • Like 1
  • 3 weeks later...
RB30/25DET
NITTO Forged internals
NITTO 1.2mm Drag headgasket
ARP Main studs
ARP Head studs
Nismo Engine mounts
9.5L ASR sump
Moroso external oil pump
ROSS Harmonic balancer with pump drive kit
Ported head
HKS 256/264 cams
Greddy Plenum
Speedfab Exhaust manifold
Twin TIAL 36mm Wastegates
HKS T51R KAI turbo
4inch Custom turbo back exhaust
100mm Intercooler
2000cc ID/Bosch Injectors
SX Fuel reg
Twin entry fuel rail
2x Bosch 044 Fuel pumps
Nismo Intank Fuel pump
E85 Fuel
Standard RB25DET gearbox
JB Single plate Full Monty clutch
Tomei Trax 2 way LSD
Supporting mods etc etc etc
547rwkw@25psi
  • Like 3
Nissan Silvia S15
Full Backyard Conversion RB26/30DETT
Block honed bored and fully forged. 8.1:1 Compression
Extended Crank collar fitted, ARP bolts/studs throughout
Nitto Oil Pump, oil restrictors fitted, head oil drain.
Nismo Water Pump, thermostat and oversized R32 GTR radiator
HKS 2530's with braided lines
HKS Cam Gears and 264 Cams, Tomei cap studs
Trust/Greddy Suction kit
Fuel lines, billet rail and 1350cc injectors
Haltech Platinum Sport 2000 inc. 3 Bar Map Sensor, Boost Controller, Dual Wideband 02 Sensors
Upgraded 100x300x600mm intercooler
LS1 coil packs
twin 3" into 3.5" straight through exhaust
Heavy Duty clutch, Flywheel, Nismo slave, Pivot and braided lines
R33 RB25 Gtst gearbox Custom 3" Tail shaft.
not to sure about the diff at the moment but i think it is a stock JDM S15 3.692 ratio
Made 377.7rwkw safe run in tune. will upload Dyno tonight
r33 gtst
mods are built engine rb25/30 with neo head cr 8.5:1
cams are 270 9.11mm
garrett gt3788 0.89 exhaust housing
turbosmart hypergate 45mm wastegate
haltech platinum pro plug in
PE 850cc injectors
nismo adj fuel reg
044 external/surge tank, 2x walbro internal pumps
3.5 catback, 3 inch dump, no cat
trust intercooler 600x300x76mm thick
320rwkw @19psi
power is a bit lower than some on here not sure why really :( would like to hit 350ish :) with these mods
stock rb25 head, no vct
rebuilt rb30 block with mahle forged pistons and the usual pump drive upgrade driving stock oil pump
ross balancer
trust low mount exhaust manifold
3" straight through exhaust
38mm tial gate
gt3076r 56t turbo
2.5" intercooler piping with 560x380x75 custom return flow intercooler
stock intake manifold with stock throttle bored to 60mm
bosch 680cc injectors, 044 fuel pump with adjustable reg.
microguess ecu running six bosch coils
want to change ecu and put 3.5" exhaust on next
Edited by Dobz
  • 1 month later...
results are in.
Blue us RB30 orange is rb25. full comparison and nothing else has changed except the bottom end.
turbo is 3076 56t with 0.63 rear... falls over pretty hard and adding more boost doesnt increase it.. so rear is a restriction thats for sure. Need a .82 rear for it.
88 series 2 vl Calais rb30et (I no not a skyline but still the rb30....)
Original turbo block
No cam or piston work
Garret t3
660cc injectors
Internal and external Bosch fuel pumps
Boost actuator ( can't remember the poundage)
Bigger fuel rail
Microtech ecu
High flow cat
2.5" exhaust cat back
13psi
230rwkw @168kms
479 nm @ 135kms
Sorry again not a skyline
post-82941-0-66739000-1344249886_thumb.jpg1995 Series2 R33 GTSt.
RB25/30
Flat top CP pistons
Forged Precision H beam rods
Polished standard size RB30 crank
Stock 25 oil pump, 1.5mm restrictor, wide op drive
Stock 25 vvt head, removed ex humps and intake cleaned up. No vvt.
6boost mani
50mm Turbosmart wg with 17psi springs plumbed into front pipe near cat
GT3582r
3 inch front pipe, gutted stock cat, kakemoto catback.
600x300x100 bar and plate ic with 2.5 ic piping.
Stock recirc valve with grub screw
910cc at 3 bar JECS sidefeed inj in stock rail with stock reg
Walbro intank
Haltech e11v2
HKS twin plate clutch
Made 400rwhp (298rwkw) at 19 psi and 415rwhp (309rwkw) at 22 psi. Made 400rwhp by 4800rpm. Didn't bother turning it up more due to the stock head internals and restrictive air filter and exhaust. Full boost at about 3500rpm.
The air filter was almost sucking itself inside out. The cat and catback are probably a restriction too but in saying that the car is very quiet.
It is what it is. I'm not happy yet so better results yet to come ;)
Edited by Room42
  • 1 month later...
RB30/25DET
9.5:1 CR
Standard RB30 Crank
Forged / Balanced
Tomei Oil Pump
Oversized custom Sump
Solid Conversion To Head
Custom Cams
Oversized Valves
Ported / Polished
1/2 Inch Head studs
Nitto head gasket
greddy intake manifold
6 Boost Manifold Divided T4
GTX35R ATP 1.06 Exhaust housing Divided
Twin tial Wastegates
4 Inch Exhaust
2x Bosch 044's
ID1000cc Injectors
$100 EBAY INTERCOOLER :thumbsup:
RB25DET gearbox
NPC custom clutch
on 24psi Eflex (caltex flex Fuel)
Edited by BMYHOE
Nissan S15 Silvia
RB30 stock bore size / milled to achieve 8.8:1cr
Wiseco pistons
Steel rods
crank collar fitted/crank balanced
Tomei head gasket
ARP RB25 head studs
stock head
stock (machined) exhaust manifolds
1st round, about 1.2 bar, R34 elbows, greddy downpipe, R34 stock catalic converter, 3" Fujitsubo catback (60mm backbox inner diameter):
2nd run, about 1.3bar boost, exhaust changed to a 3.5" one that came off an MK4, but still with some 3" restrictions, downpipe modded to fit a 100cpi catalic converter (boost reading on printout is wrong, measured at wastegates):
3rd run, still on HKS GT2530´s, but now with about 1.35 bar boost and fully custom 3" elbows + downpipe:
Now with different custom intake piping and GTX2860R´s on about 1.7-1.8 bar boost (and obviously a bit less ignition and not yet optimised A/F ratios) - we usually ran the car at 1.5 bar, just tried it once on the dyno with more boost (and were disappointed by all the results that day):
  • 4 weeks later...
So, car finally got mapped but it looks like stock fuel lines give too much backpressure - so 1.7 bar was the save limit before mixture leaned out, which disappointed me a bit.
We still could get much more power out of the car, by adding about 10 degree of ignition timing - no wonder we made such poor results the last time ;-)
Edited by AndyStuttgart
  • 2 months later...
  • 4 months later...
owner built 30/25 w/vct
Fully built motor
Tomei Poncams
1000cc bosch inj
Precision BB 6262
6Boost ex mani
Plazmaman Plenum
Power FC
etc etc.. with street legal cat
Pump fuel BP98
431hp atw@ 16psi first safe tune on second motor.
  • Like 1
  • 1 month later...
Nissan Stagea 1996 AWD
Stock RB30 block apart from new rings, bearings, big end bolts, Tomei sump baffle kit and N1 oil pump. Stock R33 head cleaned up, VCT connected, Tomei head gasket and adjustable ex cam gear. Sinco Customs exhaust manifold, GT3540R turbo with .63 ex, Synapse 50mm W/G, Venom 5in 100 cell cat, 3in exhaust with straight through resonator and cannon. Hybrid FMIC, Greddy copy FFP, HKS Sequential BOV, Deatschwerks 550 injectors, stock throttle body, fpr and rail. Walbro in tank fuel pump and Bosch 044 from surge tank. Link G4 ecu. 98 Pump gas.
Plan to install some better plugs, fine tune W/G and retune for a few more KW but will probably leave it at that as I don't want to push too hard on a stock unbalanced bottom end.
Credits: Joe (Joes Mechanical) Glenn (GDS motorsport) and Soichi (ST Hi-Tec).
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
