Hi guys,
I recently finished my forged 25/30 all built and wired up the my garage by myself.
Parts consist of:
Mahle 86.5 pistons @ 8.5:1 cr
spool rods
arp gear throughout
nitto oil pump. using one 1.5mm restrictor, with the other blocked.
vct internal feed
ross race balancer
complete bottom end balanced
rebuilt head with std cams and valves
Performance valve springs
1.0 mm cometic headgasket
ebay inlet manifold 90mm tb
aeroflow fuel rail
1400cc injectors
ls2 coil plugs mounted as coil on plug
hybrid exhaust manifold
kinugawa t67 with t04 compressor
turbosmart 45mm gate
turbosmart boost solenoid
3in straight through exhaust
walbro 460
haltech ps2000 with racepak dash
currently on its run in tune, 288kw @ 17psi and only reving to 6k rpm on bp98
Edited by Pridenjoy
Forgot to post the final tune. After all the waiting, the end result is a little disappointing, expected a bit more grunt, but not over yet, a few things to sort out .
Going to beef up the fuel and exhaust.
Flex tune and see how it goes.
  • 1 month later...
RB25/30 NEO
Spool rods
wiseco pistons
Balanced
Arp everything
N1 pump with billet gears and oil relief setup. and longer crank drive collar
ASR 8.5L sump
Standard head with 270-9.2mm cams no vct
performance valve springs
6x LS2 coils
cpc plenum
steampipe manifold
GT35 .82 rear internal gate
660CC injectors
420hp @22psi injectors at 85% duty cycle
Also couldn't get it to hold more boost up top (could of wound the pre-load up but decided against it)
BP98 fuel
Auto
  • 3 weeks later...
RB 26/30
BW S362 / 88-75
Fullrace twin scroll manifold
270deg cams
etc....
Dialled cams for low down at the cost of some top end. Boost is only 17psi while I get used to it, so there's a lot left in reserve.
0E5CABF9-BB4D-4833-86D0-457E5070507E_zps
  • Like 1
  • 3 weeks later...
RB30 bottom end, RB26 head
Forged rods / 86mm Wiseco RB26 pistons, CR about 8.7:1
HKS Step 1 cams 8.7 lift, 256in 264ex, exhaust mildly ported
ID1000
RawBrokerage T4 twinscroll manifold with two Tial F44 WG (1 Bar spring presure)
EFR8374 1.05AR twinscroll
3.5" exhaust
45mm screamer pipes
Made over 600hp on wastegate pressure:
700 with manual bleed valve (unstable boost dropping to 1.45 bar at redline)
95 octane pump fuel (as setup will go to the states next year in a R32)
Video:
Edited by AndyStuttgart
  On 07/03/2015 at 4:11 AM, Nismo 3.2ish said:
Just had the first run in tune, not sure what I am going to get when it has the final tune, I will post the results. They said it was at 7500RPM ?
Nitto 3.2 Stroker Kit
PT6262 turbo
Custom 260 10.8 cams,springs and retainers
Haltech 34GTR ECU/Boost controller
3.5 inch custom exhaust ( as a DD as quiet as it could be without restricting flow)
Supertech 1 mm OS Valves set
RB 26 head, cleaned up
9Lt sump conversion/ Nitto comp Pump
Koyorad Radiator
Walbro 460Lt fuel pump, (see how it goes)
Haltech E-Flex Sensor kit
Other stuff needed to make it all work
Yokohama AD08R
Nismo Super Coppermix twin C Spec clutch / Slave Cylinder
Quaife Front diff
Modified Trannie
Nismo 2-way LSD back diff
Just leaving the final Dyno to finish my tuning experience :)
98 pump@ 22psi = 437kw
E85 @ 22 psi = 462kw
E85 @ 25.5 = 475kw
Other Dyno is overlay of old tune 98 pump 367kw @ 22psi and new tune on 98 pump 437kw @ 22psi
  • Like 1
-Freddy copy plenum
-id1000cc injectors on big rail
-Sard fuel pressure reg
-Spitfire coil packs
-China replacement turbo
-Adaptonic computer
-Rolling automotive front mount
-80mm throttle body
Made 305.5rwhp (227.4kw) on 15psi
Tubos shit. Will make more with a quality turbo.
E85 2000 cc inj
Twin bosch 044s and surge tank
Haltech platinum plug in
Gtx 35 1.06
Ported kelford cnc head
Kelford heavy valve springs etc
Tomei head gasket
Arp head studs
Kelford 272 274 10.85 lift cams
Rips stock bottem end with prep upgrade
Tomei oil pump
Rips 10l L sump and gredy oil cooler
426 kw at all 4
26 psi
Edited by danny14
RB 25/30 Neo running E85
435 rwkw @ 23 psi
Nitto I beams
Custom CP pistons 8.8:1
Garrett GTX 3582 1.01 exh
Tomei 260 type B poncam
Mild port/polish head
Tomei dual spring and retainers
1500cc ID injectors
Walbro 460 intank twin 044 from surge tank
3" straight thru stainless exgaust
Custom stainless header
NPC twin plate
Retained VCT
  • 3 weeks later...
  On 16/09/2014 at 10:04 AM, steve200b said:
Gtx3076
Tial 44mm ext gate off housing
Lt12 ecu
Eboost street
850cc injectors
Hks 256 in 264 exh vct cams
Hybrid manifold
Forward facing plenum
Precision cooler
All through a built r34 auto with 3000 rpm converter
15psi boost
E85 and lt16c computer next month
E85 lt16c Ecu 6boost manifold upgrades.
  • Like 1
  • 2 months later...
  On 21/05/2015 at 9:45 AM, Pridenjoy said:
Hi guys,
Parts consist of:
spool rods
arp gear throughout
vct internal feed
ross race balancer
aeroflow fuel rail
1400cc injectors
walbro 460
UPDATE...
After the engine was ran in I strapped it down again which it made 320kw on 20 psi, and having iat problems.
I then fit a new plazmaman intercooler and ran it on the dyno with pump e85 making 374kw on 21psi, which is all the little t67 will do.
Edited by Pridenjoy
  • 3 weeks later...
Ok about time I posted in here..
Racepace Built RB26/30
Mahle 87mm forged pistons
Argo Rods
HKS 256 8.5mm lift cams
adj cam gears
Sard 700 cc injectors
Tomei Oil pump
Tomei Headgasket
Std Coilpacks
Std Valves and head
Power FC
3.5" Racepace custom exhaust
Walbro 255 pump
Garret 2860r-5 Turbo's
HPI dump pipes
Std manifolds inlet and exhaust
R33 GT-R intercooler
Std R33 GT-R Airbox
Balanced Blah blah
375rwkw @ 17 psi BP 98 (369 for the track)
  • Like 1
  • 2 months later...
Very similar build spec and result to acsplit above.
My goals are for a responsive track car I can daily on 98 - drive and fill up anywhere.
RB30 Bottom end w/ Ross Racing Pistons & Spool forged rods
Garrett 2860 -5 Twin Turbos
Tomei Expreme Dumps
Low comp 7.85:1 (to keep things safe on 98, YES I'm staying 98 for a while)
ARP M11 Head Studs
Nismo 0.9mm Metal Head Gasket
+1mm Supertech valves with Supertech springs & retainers
Tomei Pro Cams 260 10.25mm lift
ID 1000 injectors
Autronic SMC / 500R CDI (Super Old School!) firing through Splitfire coils
Adj cam gears
Nitto Oil Pump
Single 044 pump & 2L surge tank
12791116_1183587054999874_67586165268249
  • Like 1
  • 3 weeks later...
Had the car on the dyno today.
Still early stages at the moment. Just finished running-in new the RB25/30DET. Timing and fuel is conservative, purely as we ran out of time in the day to make improvements.
A quick power run on 22psi (E85) resulted in the following:
411kW at wheels on just shy of 20psi
428.8kW at 22psi
Aiming to run up to 30psi
E85 @ 25.5 = 475kw
Update
Decided to go V-Cam :)
Lost a little up top, but it the injectors and Turbo were just about maxed, all good
The end, I hope :/
  • Like 1
390.3kW at wheels at 18psi
411.1kW at 20psi
428.8kW at 22psi
Aiming to run 30psi
Video of the 22psi run:
https://m.youtube.com/watch?v=VhnlYVwQlBg&feature=youtu.be
  • Like 2
