  • 1 month later...
Here is my result only running 8psi for run in tune. Motor is a 2630 forged bottom end, built head fully ported oversize valves ect. Running a forced performance super 94 with 1.14 exhaust housing on 6boost t4 twin scroll 4" exhaust also haltech plug-in pro on e85
  • Like 2
140000km bottom end
N1 oil pump
Std rb25det head with internal vct mod
850cc injectors
Greedy copy inlet manifold
Hybrid exhaust manifold
Precision turbo intercooler
Gtx3076r .82 rear with tial 44 mm gate of the snail
Eboost street
16psi 285kw through an auto with cam issues. Time for an adjustable exhaust wheel to see what happens
Retune with gtx3582 at 23psi
  • Like 2
Spool and CP bottom end with extended crank collar and billet gear pump
R33 S2 head with Tomei 256° cams and internal VCT mod
RIPS intake, 6Boost mani, 50mm gate and ProBoost GTX35 (.82 rear)
A1000 pump, 1200 FPR, 1200cc injectors
Haltech plugin with 3bar MAP, Air temp and Wideband
LS2 coilpacks
Running 98 for the moment
  • Like 2
  • 3 weeks later...
  • 1 month later...
What power would i be making roughly ?
rb30 standard block
rb25 head 262 cams
fully forged internals
gtr3788r turbo 40mm gate
1000cc injectors
twin 044 bosch fuel pumps
front mount
turbo back 4 inch dump to 3.5
ffp and all other small mods
Edited by ncrdbl
more to add
Dude, this is the COMPLETE OPPOSITE of results.  This is for sharing results, not asking what it should make.  Get it tuned, share the result and then we'll all know the answer :)   If you want to discuss the setup or how well its matched or should perform, start a suitable thread.
  • 3 weeks later...
Hi all...recently tuned my;
Vl turbo with RB30/25 neo head
- Built bottom end - forged pistons, rods, N1 oil pump, studs
- Ported head- type B tomei poncams,
- Front mount intercooler
- Forward facing plenum
- 2 x 044 fuel pumps
- 6 boost manifold
- GTX 3582
- Bosch injectors 2000's
I have been building this car for years which has been an ongoing project/hobby... it's a 5 speed manual, running 24 psi on e 85.
  • Like 3
- 6 boost manifold
- GTX 3582
What comp ratio as this buid is almost exactly the same as mine. i have 1000cc injectors thats all that is different and ecu.
I have 9:1 compression and microtech....the combo works well
  • 2 months later...
Not sure why I never got around to posting in here since I've had an RB30 in the stagea for 8 years now....just got it back from Unigroup after they sorted an exhaust restriction so I thought it was time to post up
This is from my rb30 stagea
* Rb30 bottom end with forged pistons and rods
* Standard stagea head
* eboost 2 @ 19psi high boost
* Garret GT35R with 0.63 housing (the baby one)...I think!
* Generic front facing plenum and stainless high mount manifolds
* Larger injectors but stuffed if I know what size or brand.
It makes 200awkw @ 4000rpm and 250@6250 with 19psi. Comes on nice and early which is what I was after.
  • 1 month later...
GTX3584RS 1.01
26psi
Max of 7800rpm
There is more in it but decided to leave it there for reliability and longevity. I have no doubt 30-32psi would deliver 560-570kW, possibly more.
Made 421kW at about 19psi - lazy curve whilst setting up boost control, so 10psi slowly creeping up to 19ish
  • Like 2
  • 1 month later...
RB3025 Neo
-260deg 9.15 poncams                     - GT3076 0.82rear with 44mm tial, 3 1/2 inch exhaust, 100 cell cat, Sinco topmount                                    - walbro 416l/ph , 1000cc x spurts   - p fc, AVC-R , E85
- Injectors at 85%, pump almost maxed plus other parts at limit, maybe a play with cam gears later but it pulls hard already.
Edited by AngryRB
  • Like 1
Worked on the boost control set-up, added 1psi in the mid range, and a bit more (1-2degrees) timing up top.
Dyno overlay isn't 100% accurate but it's close enough
Results:
  • Like 1
  • 2 months later...
R33 series 2
Head: Rb25de (r32) with Rb26 springs still stock cams
Block: stock o-ringed rb30de with new rings and bearings
Turbo:garret GT3082 .82A/R exhaust housing
ECU: microtech lt10s
Fuel: E85
stock exhaust manifold modded to fit external gate
1200cc injectors
custom inlet plenum
290ish kw @ 18psi with 799nm
funny enough made the same peak power on the same boost with this turbo on my rb25det with poncams and pump fuel
This setup has a heap more low/mid range but
  • 3 weeks later...
