On 29/03/2016 at 9:12 PM, XKLABA said:
Lets try this again :(
Rebuilt with 0.5mm bigger Wiseco pistons
New UE 260 x 10.8mm cams
OS88 with alloy shaft
Sold dyno wheels so was dynoed on 275-35-19s instead of 255-40-18s so revs are lower then indicated
Also Scott changed from Dyno Dynamics to Mainline which apparently reads lower :/
Changed coils to Audi R8 NGKs
dailed cams back to 0 deg IN and 0 or 2 deg EX to try stop lifting head knowing we where going for 30psi
Tested rear turbo feed and got more the 10psi vacuum (test gauge only goes to 10psi) @19psi boost, should be good gains left there
still on 275/35/19s
engine bay
Solid power and delivery for low mount twins near 500kw!
Just for clarification, when you say "tested rear turbo feed and >10psi vacuum" - can you explain what you meant there?   I've been REALLY keen to know about if or how much vacuum a high-pressed low mount twin setup is drawing at the intake as I have long suspect that the piping will force a restriction as required airspeed goes up and it will initially push the pressure ratio up quite high, meaning a lot of setups will go off the comp map before they necessarily actually reach their flow potential at atmospheric vs inlet manifold pressure... so choke earlier than they would.  This would confirm that theory like a mofo.
The next thing however, if that is what is happening - when you say 10+psi "vacuum", you mean atmospheric pressure (~14.7psi) - 10psi, or ~4psi absolute pressure?   That is F-ALL.   Like crazy low.   The area of the map your compressor would be working in would be similar to if you were running near 90psi with no "vacuum" at the inlet :O
  • Like 1
This result was more what I was hoping for . Had posted it on another thread but this is the update.
I have continually lost a little from the top end but still more than needed on the street, so The End, again :)
To finish it off I added
ATS Tripple carbon clutch, the Coppermix Twin had to go, it was a great clutch.
Emtron KV8 ECU
EFR8374   1.05
Koolig Crank Trigger
  • Like 3
  • 3 months later...
RB 25/30
CP 8.5:1 pistons
MRP rods, arp2000 bolts
ARP main studs
Oil pump drive adapter
RB25DET oil pump
Lightly ported r33 s2 head
Tomei 256x 8.5 poncams
Genuine greddy intake manifold
6x2200 injectors with flex fuel sensor
VH45 throttle body
150mm intercooler
Sinco twin scroll to manifold
66mm precision waste gate
Borg Warner s300sx 83/75 twin scroll .91 housing
4inch exhaust from turbo to back
Vipec i88 ECU with lithium choon
On a rough time with vct on the entire run made 378rwkws on hub dyno
video my mate made.
Still more boost and ethanol to come. Just chasing an oil pressure issue.
Edited by Looney_Head
  • Like 2
  • 4 weeks later...
RB25 head, fixed cams Tighe grind 805C 8.9mm lift, 265 degree. Hydraulic lash adjust.
8.4:1 static CR. Freddy intake manifold, VH45 TB.
6 boost exhaust manifold, 50mm Pro Gate. 3.5 inch exhaust from turbo back. 2 inch plumb back off gate.
Precision 6266CEA, single scroll 0.84 T3 flange.
Fuel - petrol.
Boost - 24psi consistent from 4200-720020180424_234850.thumb.jpg.81b3028be78b5fb623541d7af29ab32b.jpg
Issues - experienced timing scatter due to OEM CAS.
  • 3 months later...
My latest output on my 26/30 rips built engine on e85 with oem r8 coils made an extra 64hp on less boost had a missfire first went 658 with 29 with a miss and then when we replaced plugs and gapped them @.5.5 and set boost @27 psi it went the same power didnt do another power run on 29 psi little scared with the stock rods haha although they pushing these stock rods well over 500kw in nz.20180817_203954.jpg
My latest output on my 26/30 rips built engine on e85 with oem r8 coils made an extra 64hp on less boost had a missfire first went 658 with 29 with a miss and then when we replaced plugs and gapped them @.5.5 and set boost @27 psi it went the same power didnt do another power run on 29 psi little scared with the stock rods haha although they pushing these stock rods well over 500kw in nz.20180817_203954.thumb.jpg.32893ce1cd74399066b0597d13c16ee1.jpg
Always wondered why my CR was down to 8.1:1 after my stroker build.
Thinking of going to 9.5:1 and might clean the head up, maybe even a P&P .
Anyone have results for increasing the CR from factory , up to 9.5 , maybe back to back Dyno runs on the same Dyno ?
8.1... did you get some VL workshop to build the engine, either that or a seat painter that builds engines
  • 3 months later...
Stock rb25 s0 head.
Stock unknown kilometer rb30e bottom end with acl bearings, nitto head drain, rb25 oil pump and 1.1mm oil restrictors.
1.3mm metal head gasket
6boost t3 exhaust manifold
Turbosmart hypergate 45mm
Ebay inlet plenum
660cc seimens injectors
Haltech plugin
Hypergear atr45ss .82
3inch exhaust
$50 intercooler
Had a boost creep issue due to the wastegate being to small so mid range is lacking alot.
374kw was best run for the day, left it at 370kw on 24psi on bp98.
Edited by lexxi32
  • Like 2
  • 1 month later...
Upgraded the main and head studs, switched from Splitfires to an R35 coil kit to solve the misfiring above 25psi, and added a few other things. Upped the boost to 29psi and made a few extra kilowatts and more torque.
Boost control and area under the curve is a work in progress, response was better before the upgrades so no doubt it can be improved upon again. Feels good on the street and makes peak boost in the 4+k RPM range. Screenshot_20190210-173517_Gallery.thumb.jpeg.c956888a52901786600bd0804597bcee.jpeg20190210_151554.thumb.jpeg.c5f046ecff3a67df9cb089a423fd5aaa.jpeg
  • Like 5
Video of one of the dyno runs:
It made 525kW at 27-26psi. We then turned the boost up to 29psi and on the next run just as it passed through 545kW the compressor outlet pipe clamp let go at about the 6000+rpm mark. Probably would have gone close to 555ishrwkw on that run. We quickly replaced the busted clamp and fired off two more runs at 29psi, both in the 549.Xrwkw range. I still think my GTX3584RS 1.01 combo is capable of 560-570rwkw on this dyno, with boost set to about 32-33psi. But the fuel system is completely maxed out at well over 90% DC and I'm not willing to increase base pressure any higher than 56-57psi. Close enough to call it 550rwkw will do.
I have a Racelogic Traction Control system installed in the car and on the drive home I quickly discovered the previous setting of 5% slip is not enough to prevent excessive wheel spin in 3rd gear as it ramps up to peak torque. Lowering it to 4% was a little better, but 3% might be required. 0% is the wet weather setting through to 25% is minimal TC input.
  • Like 7
Emtron KV8 ECU
EFR8374   1.05
That thing is the ultimate street set-up with a heap of low and mid range torque, even way down at a mere 2,500rpm. It actually looks a little similar to my previous set-up (old spec's in signature and green curves on attached dyno sheet) although nowhere near the amount of low down torque on tap from your beast!  I guess that's to be expected with a 3.2L and ultra responsive EFR8374 vs. 3.0L and no frills HTA GT3586R.
Yeah Matt , end of the day it's what you want from your car. It's all fun but an expensive exercise ?
Here is the latest Dyno , bit hard to compare because you need same scaling setup on the printout to compare BUT it drives better.
As you can see it is hitting 24 psi and dropped off a little mid range but will be tuned again after some Klms have been clocked and a bit more boost added
Having trouble downloading Dyno ?
Edited by Nismo 3.2ish
trouble downloading dyno graph
  • Like 1
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
