well, finally got there.....
dirty 30
256deg 9.15mm lift cams
greddy intake
1000cc injectors
haltwch platinum pro
1mm mls head gasket
spool rods/piston kit 9:1cr
spool awd adapter
6 boost mani
china gt42 bush bearing
4inch zorst
5 inch metal cat
tomei intank pump
98 octane from 7/11
444.8rwkw @19-20psi
  • 3 weeks later...
  • 2 months later...
  • 3 weeks later...
  • 2 months later...
  • 2 months later...
140000km bottom end
N1 oil pump
Std rb25det head with internal vct mod
850cc injectors
Greedy copy inlet manifold
Hybrid exhaust manifold
Precision turbo intercooler
Gtx3076r .82 rear with tial 44 mm gate of the snail
Eboost street
16psi 285kw through an auto with cam issues. Time for an adjustable exhaust wheel to see what happens
Rb25/30
Nitto i beams
Je pistons
Custom cams
Custom porting
Supertech solid lifters
Supertech 1mm o/s valve,spring,retainers
Ross external oil pump/trigger/balancer
Custom sump
Billet flywheel
Bosch 2000cc
Fake greddy manifold
Home made turbo manifold
6262 .85 t3
463kw 1082nm 23psi
E66 united
Tuned by mrc dyno castle hill
  • Like 1
My home built 30DET, in a gq wagon.
R32 25de head, (no vct)
de cams, 26 valve springs,
Adjustable gears,
Inlet -2' exhaust +4' to move torque lower.
Home made steam pipe hi mount,
Tial 44mm gate
3" exhaust, 3" cat, straight through mufflers.
Chinese t04e, .63 rear.
2.5" cooler pipes,
front facing stock inlet (cut/shut)
Rb25 neo injectors
Apexi power fc.
R31 block, honed, stock rods, stock pistons, moly Hastings rings, acl race bearings, VL turbo oil pump.
Mls-r 1.3mm head gasket.
244.3 hp atw on 33" tires and through a patrol drive line. 4.9:1 diff.
Turbo is really crap and way to small to make more power but it's built for grunt. Not outright hp. post-92047-0-73206500-1406771521_thumb.jpg
Edit -the small power figure is my before run, n/a rb30 single cam on straight lpg. Was a sad thing to drive!
Edited by nicksamaniac
  • Like 2
  • 1 month later...
Gtx3076
Tial 44mm ext gate off housing
Lt12 ecu
Eboost street
850cc injectors
Hks 256 in 264 exh vct cams
Hybrid manifold
Forward facing plenum
Precision cooler
All through a built r34 auto with 3000 rpm converter
15psi boost
E85 and lt16c computer next month
Edited by steve200b
  • 1 month later...
R33 Series 2 RB25 head, RB30de Bottom
Gtx3076, 0.82 rear
Steam-Pipe Manifold
ID1000 injectors
VCT enabled
Vipec ECU with Haltech LCD screen
United E85
367.3kW @ 18psi. Made 385kw on 20psi but used for continous track laps - final tune attached
(how do you attach an image.... :unsure:_)
R34 GTR RB26 head, RB30DE bottom
Standard Valves, dual valve springs
Custom forged CP Pistons
Tomei Cams (Can't remember specs, will find out)
2860 -5s
Tomei cam gears
Walbro 460L(?) E85 fuel pump
Custom dump pipes
Custom 2.5" front pipes
Custom 3.5" exhaust
Standard Intercooler
Standard Airbox
E85
30PSI
Edited by R0yalT
  • Like 2
Fully built RB30/26. PTE 6266. Tomei Poncams. 98 RON Pump Fuel.
485whp @ 0.9 bar
615whp @ 1.6 bar
(Forgive me for the stupid torque axis, was too excited after the tune haha)
Edited by G37Sam
  • Like 2
  • 1 month later...
Rb26/30
Cp flat top forged Pistons
Precision h beam rods
Acl race bearings
Balanced
Os giken twin plate clutch
R32 stock head machined 120thou
Stock fuel pump, airflow meters, injectors
Apexi pod filters and cast bends
Nistune ecu
R34 GTR dump pipes , full xforce 3.5 inch stainless exhaust
Standard cast manifolds with garrett/hks gtrs twin turbos tuned on bp98 fuel post-134876-14194237982441_thumb.jpg
  • Like 1
  • 2 months later...
Just had the first run in tune, not sure what I am going to get when it has the final tune, I will post the results. They said it was at 7500RPM ?
Nitto 3.2 Stroker Kit
PT6262 turbo
Custom 260 10.8 cams,springs and retainers
Haltech 34GTR ECU/Boost controller
3.5 inch custom exhaust ( as a DD as quiet as it could be without restricting flow)
Supertech 1 mm OS Valves set
RB 26 head, cleaned up
9Lt sump conversion/ Nitto comp Pump
Koyorad Radiator
Walbro 460Lt fuel pump, (see how it goes)
Haltech E-Flex Sensor kit
Other stuff needed to make it all work
Yokohama AD08R
Nismo Super Coppermix twin C Spec clutch / Slave Cylinder
Quaife Front diff
Modified Trannie
Nismo 2-way LSD back diff
  • 4 weeks later...
RoyalT managed 450kw with a walbro 460ltr fuel pump and u are also using the same pump...sounds positive!
Are u guys running these fuel pumps independent as an intank?
My pump is just a normal setup and replaced a Bosch 044
Going in next week for the final tune and will post results, busting to see if I get the car I tried to build :)
Edited by Nismo 3.2ish
  • Like 1
