hey guys
looking to but a car thats hit in the front, pole.. motor looks to be pushed bak a few inches.. jus wondering wat possible problems could this bring on.. could i jts replace the crossmembers , repair the damage n hopefully its ok.. or woul there be defiate drveline issues?? thanks guys, help needed asap as im goin to go tomoz to say yes or no.. thanks
Depends where it hit, if it belted directly into the front of the car and ijto the motor, without a doubt it'd require at a minimum a full tear down to check everything for straightness or internal damage..
beyond that, if the motor has shifted back, this means one, or both of the chasis rails has moved, meaning it has EXTENSIVE structural damage and i would highly recomend you turn it into parts
Its very hard to say you need to inspect very thorough , look for bent front rails . It could be just engine mounts broken or bent rails , pushed back A pillars to a completely bent floorpan . Check to see3 if the doors open and close easy and the gaps on all the doors .
hlooking to but a car thats hit in the front, pole.. motor looks to be pushed bak a few inches.. jus wondering wat possible problems could this bring on.. could i jts replace the crossmembers , repair the damage n hopefully its ok.. or woul there be defiate drveline issues?? thanks guys, help needed asap as im goin to go tomoz to say yes or no.. thanks
Aside from the chassis damage, if the harmonic balancer has been impacted it's possible there's internal damage to crank thrust bearings, etc
RU34ME: Anything is repairable as long as you have it done the right way and by the right person it can be as good or even better than when new. But whether it is worth fixing is another story all together.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
