Stripping Complete - S14 97 High Spec Pics
Hi Everyone,
I’m stripping a complete undamaged 97 high spec s14 200sx in Sydney. I have listed most key parts below and also the couple of bits that have been sold. If you need anything in particular let me know.
Contact detail's: Ben - Just Post or PM here to discuss further
I’m happy to work out a discount if your after multiple items so just PM with the bits you want and I’ll work out a price.
Headlight Assembly - SOLD
Taillight Assembly – SOLD
Perfect Bonnet with badge - Sold
Boot, no spoiler but with the built in stop light - Sold
Left Front Guard - Sold
Grill - Sold pending payment
ABS module - Sold
Complete undamaged shell Starts at $300 then goes up depending on whats still attached to it. SOLD
Standard Driving lights to suit the above front bar - SOLD
Ignition barrel & lock - Sold
Washer bottle & pump - Sold
Front Seats - Sold
Complete Rear end (diff, hubs brakes etc) - Sold
Complete front end (cross member, LCA, Brakes, hubs) - Sold
Instrument cluster – Make an offer - 155,xxx kms - Sold pending payment
Complete Eng - SOLD
Centre console, lid hinge busted otherwise good - SOLD
Standard Exhaust, Clear that defect - SOLD
Air conditioning system *complete & uncut & undamaged*, compressor, condenser etc **Offers** - SOLD
Stock pump with all the stuff attached - SOLD
Booster & master cylinder - SOLD
Loom/ECU - $300
auto box - with everything required was $100 now $40
Right Front Guard - was $220 now $150 with blinker
Right Door skin with hinges $160, door handles $25, glass $50 or the lot $190.
Left Door skin with hinges $160, door handles $25, glass $50 or the lot $190.
Left door trim, $50 which includes door handle surround
Front bar including blinkers - was $175 now $100 with no blinkers
Rear Bar - was $175 (No reflectors) now $100
Passenger Airbag - was $100 now $50
Dash nothing attached $40
Boot lining complete- * including the timber bit was $70 now $40.
+ lots of random interior & engine bay bits. NOTE: the stereo surround is sold.
Feel free to PM me with any obscure bits that you might need
Edited by fly510
 Share
    • You don't need an AC mechanic to fit it. You do need one to vac the system down and fill it. That's how you get refrigerant.
    • Well, it's actually probably worse than you think. I think you have to (minimally) install GKTech's spherical bush replacements to the lower arm's inner ends, because you absolutely cannot subject the original (or poly) bushes to that much misalignment. The better option being to replace the whole lower arm with GKTech's unit. This brings sphericals to the lower inners either way you do it. And are you aware that the kit is weld in and you have to take the subframe out of the car to get it fitted? It's a fair bit of work. These issues both drive my ongoing dithering about doing this to my car, for the last couple of years.
    • The website said you need a AC technican to swap it in. Is that true? How did you fill the refridgerant? Was it easy to install?  If i just got the bracket and the new smaller AC compressor, would the other components be compatible with R134?
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
