Don it 1 at nicholson rd yale garden st rounder bowt
i was not going to fast 70kms but i had never experenced it before
back end went loose with no lose of traction so i slowed down a little
went home and changed the undies
i am considering removal aswel
james
  • Replies 84
on r32 its hydraulic from power steering fluid,on r33 pretty sure electronic,
pull the fuse out on r33 (hicas light will be on dash) that gets rid of it for free !
Edited by turbohectics
hahaah, im keen on a group buy, but im located in NZ?i need gettin rid of HICAS
Then there were 2.
33's are electric but you cant just pull the plug. The best way is by removing the entire rack and replacing it with a steal bar like the ones GTRGeoff (SkylineGeoff)makes.
Hey Geoff, your getting plenty of plugs here :O
Hi GMR33, sorry but I havn't been looking much, and tend to not try to "plug" my stuff by intruding on discussion. If people want them they soon find me.
In this case though I can offer some advice on HICAS, as I have 3 Skyline R33's to compare. R33GTS25tt (yes TT) without HICAS (my poor broken track car), R33GTS25t auto with HICAS and R33GTR with HICAS (soon to be without).
The HICAS is designed to induce understeer over 80kmh. Understeer is considered the safest response for numpty drivers. The problem though when racing/driving at or near the limit is that as you enter the corner on your line, the HICAS then turns the rear toward the corner causing understeer so you turn in more to hit your mark. But because HICAS then runs out of turn angle the rear then starts to take over and you will slide the rear a bit, especially if you set the car up a bit harder on the rear bar, or you compression slide like I do in the auto and GTR. So now your are winding off lock, and maybe oversteer a bit so HICAS turns out of the corner trying to turn you around. You can then end up in the tank slapper (or sankey, like a porka 911) and usually a wall is right where you don't want to be.
It's fine for normal driving, but can catch you out as soon as you have a play without warning. So I don't recommend disabling it for everyone, in fact the auto is keeping it as it has to go (5 cars is apparently too many the wife says :rolleyes: ) but I do skidpan stuff in the GTR and drive it daily through some fun places so it has to go.
Bad news is I have only a few R33/34 fabrication kits left and they are more or less spoken for by some mates, but there are plenty of R32/180/Silvia kits left. I have no plans just yet to get more parts machining done until the R32 ones are almost gone as I'm redesigning the threaded inserts for easier fabrication.
I'll see how demand goes though for 33/34 and may bring them back sooner.
All other info is below.
Cheers
Geoff
Hi Geoff, thsi link doesn't seem to work, or is it my stupid firewall?
Instructions
http://url=http://www.skylinesaustralia.co...showtopic=58778
:P cheers :)
Fixed mate, and thanks for the heads up. An extra bit of crap got into my sig instructions.
Hope that item I sent is satisfactory.
It's fine for normal driving, but can catch you out as soon as you have a play without warning. So I don't recommend disabling it for everyone, in fact the auto is keeping it as it has to go (5 cars is apparently too many the wife says :( ) but I do skidpan stuff in the GTR and drive it daily through some fun places so it has to go.
Cheers
Geoff
I would love one of these too... count me in if you do another run
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
