  • Replies 84
OK guys there seems a bit of interest so I'll start discussions with the machinist and see if I can get another run done. I'll post up details on timings expected.
Geoff
Sweeeet,
That is good news mate, put me down for one.
I reciently hit a huge bump in the middle of the road and now it seems like my car is steering from the back. I think maybe its a toe in/out issue but it looks like I am going to need a wheel alignment in the back. Anyway I dont want to do this until I have the hicas replacment bar fitted...
would the steering from the back be a toe / camber issue after hitting a big bump with both rear wheels?
Sweeeet,
Sure sounds like a toe issue, or the rod ends could be buggered. Just got a set for the front of the auto as one is clunking. Get under and look for anything bent or with flaking areas.
im about to have mine removed by my tuner. v good price too considering custom machining of lock bars etc.
does anyone advocated for hicas in racing conditions... track days etc.!!!
i dont wana remove it for no reason my car has everything done to the suspension but this as it is setup for circuit avs suspension said it has had the most work done that he has seen on a street car. ? why has hicas been left??
  • 1 month later...
GTRgeoff
You know I want one of those lock bars for my 33 aswell, so put me down on that little list you got going :P
Hope you can get something going again, I'd much rather throw some coin your way than go with the Tomei kit!!!
Come on lads, more interest hahah
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
    • Hi. Yeah i think that DIS-008 should be ok too but i rather asked. The R8 coils are "sadly" no go for me cuz every solution is for forward plenum. The coils are too tall and one of the(4/5 DK) would not fit under stock J-pipe. And being this NA RB20 i dont even know where to get some forward plenum.(and of course i would need other stuff like custom AFM/ECU etc) and that is kinda non sense for NA without boost. I just looking for solutions for my case 🙂  I try look into those Yaris/Corolla ones.
    • Damn it, no, I topped up before I got to yours I really should look at Costco locations more when I'm out and about burning through fuel
    • Did you hit the one 5 minutes down the road from my place before heading back south? 😛
