ive just finished replacing my plugs with bosch fr8 dcx with a 1.1 gap.
The car is detonating all over the shop. runs really smooth under boost. But if you put foot in, it just starts going put put put and hesiitating.
weird as it runs really smooth apart from that.
Help?! I am over this car!
Do not use any conti plugs, use Denso or NGK brand. They are more suitable for jap made ride. Since you have already bought the bosch, set the gap down to 1, if detonate then down to 0.9 so on and so fore.
So i can pull these out and change the gap?
please explain. In the past ive hit up the old man who is a mechanic and he has given me a set and we are away.
Ill do that tmrw morning and see what happens. I;m guessing you need those filler guages thingymebobs?
conti plugs? what is that?
Yes, you need a feeler gauge and a long nose plier.
Conti plugs mean European brand like Bosch, voker or brisk.
Edited by Trex101
I've got denso iridiums IK16, set at 1.05mm, so whats the heat range of these plugs and are they ok for my car or do i need to change them? i was going to change them anyway but if these aren't what i should get then i'd like to know before i get new ones.
IK16 is about a number 5 NGK heat range plugs. IK16 may be too hot for your ride, choose IK20 (equal to NGK heat range 6 plug).
bosch wr8dcx for rb25det, any good? It sounds like it is breaking down under load.
I previously had NGK bcp5es in the car and they were good up until 5000rpm then powere flatened out and it seemed the car was held back by soething.
Maybye a vacuum line not hooked up properley?
Help!
r33 s2,
I had them gapped at 1.1 and they were a bosch pulg with a heat range of 8.
The guy at the service station got the specs out of book but obviously they are complete shit as car run better with ngk with a heat range of 5 and a 1 mil gap.
thanks once again goes to SK, and those that backed up his opinions :(
Put some bcpr6es' in yesterday, gapped at .8, after running iridiums for 40K odd. Idle is now smooth as instead of the occasional misfire, and seems smoother right through the rev range. It also seems to run slightly cooler, although I haven't taken it for a long run to confirm this yet.
Just a couple of small questions -
when I put the new plugs in the idle dropped slightly. Yes, I currently have the (throttle) bypass valve disabled. The gap of the old plugs was .8 too. What does this point to?
Also, if anything, the car has slightly reduced power, however this could just be my mind playing tricks on me, given that it also feels smoother now.
My guess for both of these questions is that I may be able to get away with a slightly larger gap now.
Before changing the plugs, I was running at just under 12 psi, however the car was starting to hesitate and pop under full throttle at around the 3500 mark, so I dropped the boost to 10.5ish. I've never heard pinging on a boosted motor, but I can't say that I heard anything like pinging when this was happening(tho I'm not sure how audible it would be over the din of the motor and exhaust), which led me to the conclusion that it was more likely missing (due to sparks blowing out) moreso than pinging. would that be right?
So my question is this - what is the better option, re-gap the plugs or increase the boost again?
Edited by jezzerrr
hmmm....
What is the difference between a "BCPR6ES" and the "BKR6E-11"?
other then the gap difference, they are both copper plugs with the same heat range correct? I bought the BKR6E-11's after i found my local shop didnt have the normal plugs in stock.... however, the BKR6E's have the same number as the iridium plugs without the prefix, and were listend under the performance column. can anyone shed light on the diferences?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
