ive just finished replacing my plugs with bosch fr8 dcx with a 1.1 gap.
The car is detonating all over the shop. runs really smooth under boost. But if you put foot in, it just starts going put put put and hesiitating.
weird as it runs really smooth apart from that.
Help?! I am over this car!
Do not use any conti plugs, use Denso or NGK brand. They are more suitable for jap made ride. Since you have already bought the bosch, set the gap down to 1, if detonate then down to 0.9 so on and so fore.
So i can pull these out and change the gap?
please explain. In the past ive hit up the old man who is a mechanic and he has given me a set and we are away.
Ill do that tmrw morning and see what happens. I;m guessing you need those filler guages thingymebobs?
conti plugs? what is that?
Yes, you need a feeler gauge and a long nose plier.
Conti plugs mean European brand like Bosch, voker or brisk.
Edited by Trex101
I've got denso iridiums IK16, set at 1.05mm, so whats the heat range of these plugs and are they ok for my car or do i need to change them? i was going to change them anyway but if these aren't what i should get then i'd like to know before i get new ones.
IK16 is about a number 5 NGK heat range plugs. IK16 may be too hot for your ride, choose IK20 (equal to NGK heat range 6 plug).
bosch wr8dcx for rb25det, any good? It sounds like it is breaking down under load.
I previously had NGK bcp5es in the car and they were good up until 5000rpm then powere flatened out and it seemed the car was held back by soething.
Maybye a vacuum line not hooked up properley?
Help!
r33 s2,
I had them gapped at 1.1 and they were a bosch pulg with a heat range of 8.
The guy at the service station got the specs out of book but obviously they are complete shit as car run better with ngk with a heat range of 5 and a 1 mil gap.
thanks once again goes to SK, and those that backed up his opinions :(
Put some bcpr6es' in yesterday, gapped at .8, after running iridiums for 40K odd. Idle is now smooth as instead of the occasional misfire, and seems smoother right through the rev range. It also seems to run slightly cooler, although I haven't taken it for a long run to confirm this yet.
Just a couple of small questions -
when I put the new plugs in the idle dropped slightly. Yes, I currently have the (throttle) bypass valve disabled. The gap of the old plugs was .8 too. What does this point to?
Also, if anything, the car has slightly reduced power, however this could just be my mind playing tricks on me, given that it also feels smoother now.
My guess for both of these questions is that I may be able to get away with a slightly larger gap now.
Before changing the plugs, I was running at just under 12 psi, however the car was starting to hesitate and pop under full throttle at around the 3500 mark, so I dropped the boost to 10.5ish. I've never heard pinging on a boosted motor, but I can't say that I heard anything like pinging when this was happening(tho I'm not sure how audible it would be over the din of the motor and exhaust), which led me to the conclusion that it was more likely missing (due to sparks blowing out) moreso than pinging. would that be right?
So my question is this - what is the better option, re-gap the plugs or increase the boost again?
Edited by jezzerrr
hmmm....
What is the difference between a "BCPR6ES" and the "BKR6E-11"?
other then the gap difference, they are both copper plugs with the same heat range correct? I bought the BKR6E-11's after i found my local shop didnt have the normal plugs in stock.... however, the BKR6E's have the same number as the iridium plugs without the prefix, and were listend under the performance column. can anyone shed light on the diferences?
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
