I gapped my plugs down to 0.8mm tonight and it has deffinatly made a difference, the hesistation down low has almost gone (still hesistates a little bit sometimes), and it dosent seem to feel sluggish down low anymore.
When i pulled the plugs out the tips and the white porcelain was all very clean (almost brand new looking), but the conductor (the part that you tap down to reduce the gap) was white, and also the white porcelain just above the hex part of the spark plug (same shape as a nut) looked like it had a little bit of white powder around it and also looked a bit blistered
Which possibly means that i need to go to a colder heat range spark plug (most likly a heat range 6) Can anyone confirm if my plugs heat range 5 is ok for my application (i only have a catback and decat pipe at the moment but will be adding more mods in the near future) or judging by my explanation above are my plugs overheating??
Cheers
Jason
Cheers
Jason
I would be easier if you have a picture of your plugs but from your description, it looks like it's a case of overheating. A number 6 NGK would have solve your overheating & possible hesitation problem.
Edited by Trex101
Sorry i didnt take a pic, i might just go and buy a set of NGK R's BKR6ES11 (heat range 6) and gap them down to 0.8mm and see how i go, if i do decide to do that i will post up the results
Cheers for all the help guys
Get the BKR6E-11 instead, that the better plug with V grove.
  The Mafia said:
no, get the BKR7E.
Its a 7 heat range plug, and is pre gapped to 0.8mm.
Forget getting all of these other types. Its been proven about 10 tines on SAU that the best plug for the RB25DET is the BKR7E
are they the coppers? BKR7E-11?
  The Mafia said:
no no no
BKR7E
There is no "-11"
If there is no -11 on the end it means they are default gap of 0.8mm. Gapped from the factory.
yeah thanks sussed that out...
can u get these still, I think they are hard to get.
I've ran the BKR7E plugs for quite some time now.
I usually start the car, throw on my seat belt then drive slowly off.
Recently I've been having a play and decided to let it warm for ~1-2mins before driving off and the BKR7E's tend to foul a little. Its only very very slight fouling and they do clear up pretty quickly once driving.
I found Autobarn was the only auto store in Adelaide that I could get the BKR7E plugs from.
Motortraders/Coventrys, Sprints, Motormates, autopro etc said nope we can't get them. :ninja:
Repco wanted to charge me freight costs or what ever it was.
Motortraders are well priced. 6 BCPR6E plugs for $18. :/
I just put in some NGK BCPR6ES (heat range 6 and come pregapped to 0.8mm) and the car feels alot better down low and up high, although there is still some slight hesistation around 2500-3000rpm which im not sure what the cause of that is.
  • 5 weeks later...
The BCPR6E plugs that are also suitable for the R33 can be had a Motor Traders / Coventry's for $2.85 per plug. :laugh:
I've ran the BKR7E plugs in my R32 and found them to be a touch too cold for a daily driver. :wave:
I tried everything, leaned the water temp correction right out but found the plugs to live a short life, they did ~15,000km's fine before crapping out.
I've since shoved the BCPR6E plugs back in and they look much healthier upon inspection at 10k.
The 6's usually last 30-40k. 40k they really look worn but still work fine. :kiss:
  • 1 month later...
i just pulled my plugs out as im still having misfiring issues above 16psi and the are the bcpr7's gapped to 0.6 and the tips are white!!! they have only been in car for 5000ks
does this mean they are running too hot?
i have a set of 1.1mm iridiums in the 6 heat range, can these be gapped? the electrode looks pretty fragile :P
dea?
aarrgh now u got me worried.
getting another rb20 dropped in next weekend but need all supporting stuff working..
fuel pump has been pretty noisey lately! how can u tell if they are buggered? will a pressure regulator help the situation?
:P
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 馃槅 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 馃檪 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
