  • 4 weeks later...
After reading all 10 pages, i understand the importance of 0.8mm plugs over 1.1mm in a boosted situation.
However i am still unclear on weather to go for a '6' heat range plug, or a '7' (slightly colder) plug.
1. My car is a daily driver
2. About to get about 220rwKw (seeing boostworx next month to install powerfc!)
3. Want to run 10-12 psi.
Does this mean I should go for the slightly colder '7' range plug, specifically the BKR7E?
Trav33 im in the same boat.
I just had my car dyno'd at 175rwkw with full exh inc dump pipe etc and a pod filter.. running stock boost on mine..
On the dyno we saw a peak boost of 10.48psi.
It misses/knocks around 5500 rpm so my tuner (world reknown soichi) said i needed NGK #7 plugs..
This is my question.. Do i run BCPR6ES or the #7 plugs?
im not going to bother with platinums or iridius as iv heard they are shit.. so yeh!
  • 5 months later...
Sorry to bring an old thread up!!
But i normally run BCPR7ES 0.8
But apparently i heard they stopped making them
SO i bought BPR7ES
^ notice its without the c
Is there much difference? should i use it?
pls do let me know
ok i need some help, im running a rb20 at around the 12psi mark, i noticed at the last drift prac day my engine started to deteriorate, it was stuttering up near the 4k mark, had issues idling and would often stall when coming down from above 2-3krpm, also felt different coming from acceleration to deceleration as i lifted the throttle at high revs. now i thought this could have been heat issues with the igniter module and coilpacks etc breaking down, but it continued the next day and still having it a week on. now i got shaun at boostworx to have a quick suss, couldnt see anything serious, so my thoughts have turned to plugs. i know they havnt been replaced in a while, i cant remember what went in there as it was about 1.5 years ago.
my thinking is that from the hard work the engine did the heat or something has broken down some probably already warn plugs and this is the cause of the issue.
so i guess my next question is what do i go to next, ive read through the whole thread and the recommendations seems to be at base for 12psi the BCPR6ES – 8, but ive also read about the v-power and that sounds like a good idea too, and the BKR7E etc.
my head is bursting with all those codes so im not even gonna bother with trying to remember what is what.
but yeh i guess what im asking is what plug would be the best for me? the car does get used on the track and the engine does get a work out so would going the higher temp one a better idea? i think the gapping at 0.8 and the v-power design is the way to go for my car, but yeh the temp thing is probably what's not too clear for me a the moment.
Pull them out and have a look.
In the past I've found the BKR7E to be fine; they would only foul 'slightly' if I left the car idling to warm up. Simple drive the car soft; no need to idle for minutes upon minutes. :laugh:
I know Shaun likes his 6's but I've found 200rwkw and over they tend to come out looking a little hot. Drop 7's in and they look just right.
lol you found some old Y's.. NGK dropped the Y from the BCPR6E range a good 4-5years ago.
The BCPR6E and BCPR6EY are the exact same plug. V groove and all.
Motortraders do BCPR6E spark plugs for around $2.85 each. Which is a bargain. :domokun:
haha well, turns out i already had some in there and they werent really f**ked besides some carbon build up. so a night's work later and some cut to f**k hands and no difference. on the good side, i took it up the hill and thrashed it a bit and ended up with a car that now miss fires the whole time not just under boost. wait for new thread.
Didn't crack by doing it the slackers way and not removing the cross over pipe instead using a swivel? :)
haha nup, i took of the crossover pipe and strut brace and everything, it was just as the back where theres a few hooks and cable tie ends where they have been cut (the worst) sticking out, as well as my dodgey aluminium can recirc valve gasket i made which stuck out of the BOV and often into my hand. i hate working on engines, suspension i can deal with, everything else i can deal with, but engines, nope.
  • 3 months later...
Hey guys I noticed when I changed plugs the other day that the BCPR6ES plugs I'd had in there for ~14,000km still looked in fine condition (and ran fine too) but about 5 out of the 6 plugs had a rust coloured ring around the white part (where the white part goes into the silver nut/thread part). I gather this is due to heat. I did overheat the car one time but shoudl I go to a 7 heat range? Anyone else experienced this before?
I run a RB20 with R33 turbo, 12psi (0.8bar), runs very rich 10:1 above 3500rpm.....
Maybe I need to run 0.9bar to get the correct AFR's? It has a Blitz Super Computer sticker on the ECU.
Fixxxer
Fixxxer
The discolouration is due to electrical discharge, quite normal. Wipe it off and put the plugs back in the engine.
Cheers
Gary
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
