wouldn't i go for bkr7es (or bcpr7es) for the colder plug? or am i getting confused?
Black soot would indicate a hotter plug is needed but you might not need to change the plug if gapping it down does the trick.
ahh yep i get it, so the plug is hotter to help burn off the soot, or another way, so its not a cool area in the cylinder for the soot to form on...
That is a dangerous game to play. I would say your plugs are sooty for different reasons, most likely just rich A/F ratios the car could be R & R'ing or could just have a rich idle (bung O2 sensor) or just be a normal rich running RB with upped boost.
If your car is in any way modified, I wouldn't recommend hotter plugs; standard 6's would be a minimum.
Edited by SKiT_R31
just changed my ngk coppers (bkr6es-11's) to bosch fr7dp's (equivalent to ngk platinums gapped at 0.8) and the car is now drivable again. the coppers died after 5000km and on the day i changed plugs the car was barely drivable. was very sad.
still missing problems every now and then but that'll be the coilpacks, they're desperate for a change
  • 1 month later...
I have standard copper BCPR6ES and the car misses a few beats at idle.
At higher rpms I could not detect anything unusual.
(running 14PSI)
Is it normal that the car misses a few fires at idle?
RB25DET
Thanks and sorry for being slightly off topic.
Cheers,
Andrew
(running 14PSI)
if you're really keen to make it a bit smoother do a search, it's a pretty common problem but most people just leave it. first things to do are clean the iac and aac valves, there are diy's on them in the diy section...
but as said above, it's pretty normal
miss at idle is usually the ignitor getting tired, pretty common
Thanks guys .. I was a bit worried about the pops at low idle.
And to contribute something to this thread:
I am using these V-Line Spark plugs in my Skyline (on the right)
VLine
NGK on V-Line
I have no idea if there is any advantage to multi electrodes, but on my motorcycle it really made a difference.
(though I don't believe in Snake-Oil :verymad:)
And here's a link from NGK with some videos included (technical advice on installation):
NGK
More:
Edited by Torques
i've had a miss fire problem for months and just assumed coilpacks. hadn't even thought to change plugs. i'll just go copper so that's BCPR6ES right? RB20 running 7 PSI?i drive fairly tame 70% of the time. i bring it up on full boost probably only once or twice every drive. so that means i should go a hotter plug? or doesn't it really matter and i should just get the bcpr6es?
go bcpr6es-11's cos it's stock boost. 6 is a hotter plug, 5 is recommended. have a read of earlier pages in this thread, plenty of answers there
After finally getting my FMIC return flow installed, it took me awhile to narrow down this thing my car is now doing. If you've ever had or driven a front wheel drive car with maybe old or spongy front shocks, you'd know the feeling when you are trying to floor it and hit bumps. The car kind of shudders a little and you can feel the traction slipping.
Now with my car I have a standard turbo running the ground boosting trick. What happens is when I put my foot down, there is for sure more power there, but there's also this feeling like the car is slipping or hiccuping. Could this be due to my Bosch Plats being gapped at 1.1?
I don't know where to start to go about fixing my problem, but at first I thought I was just imaging it, but after driving around more it's there for sure. Oddly I notice it more than I have the Overdrive ON. When it's OFF and I have the Power/Snow switch set to Power it still does it, but I think the increase in revs is helping to hide the fact I've got a problem somewhere.
So guys, where do I start to look at this problem?
5 is a hotter plug, 6 is reccomended. 7 Is a colder plug and is more ideal if running more than stock boost imo. Also, a 1.1 gap is fine providing your coilpacks are in good shape, but 0.8 are what your supposed to run and will give you the least issues (especially if your coilpacks are getting old).
It's common for a missfire to clear in the higher revs, its definitely your gap, i would down it to 0.8. If you still have issues you need to source some new coil packs - you can happily gap down to ~ 0.6 but any lower and you start to really hurt your idle and light throttle/off boost.
Ah ok. I still have my old Autolite plugs, so might clean them up, gap them to 0.8 and see if that cures anything. If it does, then I'll have a go at gapping the Bosch Plats. I don't want to damage them if it turns out it's not the gap, so the Autolites will be testers hehe.
bosch plats gapped at 0.8 are like $5 more than the 1.1's, well worth the dollars cos u dont have to risk damaging them
Where can you buy them from? I got mine from Repco or something for a 6 pack @ $38 or something. They only had the 1.1 gapped ones.
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
