Hey check out ebay au, happen to see a post of NGK G-Power platinum going for $5 buck with free shipping..
NGK G-Power
Another interesting thing to note, for R32 owners etc... the coil pack PLUGS (loom side), have a tendency to DESINTEGRATE... especially if they're 13-15 years old... I've seen this happen before, and today I changed my plugs (after having missing on 2 cylinders... sounded like a WRX :D) to copper BCPR6ES-11's gapped to 0.7mm, and had TWO stuffed coilpack plugs. She runs a charm now.
Even if the inside yellow/brown section of the coilpack plug desintegrates, DONT cut the plug off... you CAN NOT buy these new (as far as i know), and will have to source them off another wreck. They still work fine if the yellow/brown plastic comes out, just push the pins/resitors back in, and connect the plug carefully... no dramas! :)
i iused the BCPR6ES and had major missfire problems under boost which then killed the plugs so it sounded like scooby. i then replaced them with BCPR7ES and all is well. i have an R32 gts-t std boost but HKS air filter, exhaust including downpipe with bov.
Im in england by the way.
Thanks John
With regards to the V-Power.
They are a little difficult to get here in SA but I have found Motortraders stock the BCPR6E.
The BCPR6E are the V-power/groove plug. I believe they dropped the Y.
From memory a set of 6 from Motortraders is around $17.
Don't bother with supercrap they wanted 3x the price.
Dirt Cheap. :D
They are..
I've been running them since they were called BCPR6EY. Around 2-3years ago for some reason they dropped the Y.
So in total including the Y's I have been running them since I bought the car 4.5yrs ago.
I have an old spark plug laying around somewhere, I'll grab a pic of it and post her up.
But as I said the only place that stocks them is Motortraders, specifically Motortraders at Edwardstown. The BCPR6E-11's appear to be a little more abundant.
Here's a quick google result.
http://www.overboost.com/obs/hin/product.a...name=Sparkplugs
and this from an old NGK link.
http://66.102.7.104/search?q=cache:sSDfG7y...lient=firefox-a
I gave them a buzz as Im going to throw in a set of 7's in a couple of weeks.
Unfortunately they don't have the BCPR7E/BCPR7E-11 or BKR7E/BKR7E-11 listed, the BCPR6E's are.
Bugger..
EDIT: And a couple pics of the BCPR6E that have done 30,000km's.
They were still running fine in the car but you can see they were on their way out as the electrode is well and truley rounded. :whistling:
No octane boosters and the like only ever BP98.
Sweet. Good stuff they have the BCPR7E then!
And yeah those sparkies look well and truely shagged. Lucky their cheap!
What gap are you running? I've found I can gap V-Powers around 0.1 - 0.15 bigger than NGK Platinums which is a testimony to their efficiency.
Yeah actually come to think of it, I've never been able to get my hands on the 0.8mm version. Always the BKR7E-11. Kinda annoying. The guys in the States debate about gapping the -11s down to 0.8mm (or less) as they say the electrode isnt parallel anymore. Still works good though..
I've noticed this also when I gapped a set down, which is why until now I've avoided gapping down.
Couldnt you guys just order in a whole bunch, group buy it on here or something?
Im going to try and find them tomorrow tho, and do it on the weekend see how it goes and all.
Quick question tho. If my little sprung coilpack contact things are gone, but the coilpack other than that is still good, what would I use as a replacement for the spring?
Well my worst fears are confirmed, 3 of 3 coil packs I pulled out had cracks and tested at the 20k ohms setting 1.5,1.6 and 1.7, I have allready found some new ones at Kudos motorsport, has anyone bought from them and these are OEM units.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
