I gapped my plugs down to 0.8mm tonight and it has deffinatly made a difference, the hesistation down low has almost gone (still hesistates a little bit sometimes), and it dosent seem to feel sluggish down low anymore.
When i pulled the plugs out the tips and the white porcelain was all very clean (almost brand new looking), but the conductor (the part that you tap down to reduce the gap) was white, and also the white porcelain just above the hex part of the spark plug (same shape as a nut) looked like it had a little bit of white powder around it and also looked a bit blistered
Which possibly means that i need to go to a colder heat range spark plug (most likly a heat range 6) Can anyone confirm if my plugs heat range 5 is ok for my application (i only have a catback and decat pipe at the moment but will be adding more mods in the near future) or judging by my explanation above are my plugs overheating??
Cheers
Jason
Cheers
Jason
I would be easier if you have a picture of your plugs but from your description, it looks like it's a case of overheating. A number 6 NGK would have solve your overheating & possible hesitation problem.
Edited by Trex101
Sorry i didnt take a pic, i might just go and buy a set of NGK R's BKR6ES11 (heat range 6) and gap them down to 0.8mm and see how i go, if i do decide to do that i will post up the results
Cheers for all the help guys
Get the BKR6E-11 instead, that the better plug with V grove.
no, get the BKR7E.
Its a 7 heat range plug, and is pre gapped to 0.8mm.
Forget getting all of these other types. Its been proven about 10 tines on SAU that the best plug for the RB25DET is the BKR7E
are they the coppers? BKR7E-11?
I've ran the BKR7E plugs for quite some time now.
I usually start the car, throw on my seat belt then drive slowly off.
Recently I've been having a play and decided to let it warm for ~1-2mins before driving off and the BKR7E's tend to foul a little. Its only very very slight fouling and they do clear up pretty quickly once driving.
I found Autobarn was the only auto store in Adelaide that I could get the BKR7E plugs from.
Motortraders/Coventrys, Sprints, Motormates, autopro etc said nope we can't get them. :ninja:
Repco wanted to charge me freight costs or what ever it was.
Motortraders are well priced. 6 BCPR6E plugs for $18. :/
I just put in some NGK BCPR6ES (heat range 6 and come pregapped to 0.8mm) and the car feels alot better down low and up high, although there is still some slight hesistation around 2500-3000rpm which im not sure what the cause of that is.
  • 5 weeks later...
The BCPR6E plugs that are also suitable for the R33 can be had a Motor Traders / Coventry's for $2.85 per plug. :laugh:
I've ran the BKR7E plugs in my R32 and found them to be a touch too cold for a daily driver. :wave:
I tried everything, leaned the water temp correction right out but found the plugs to live a short life, they did ~15,000km's fine before crapping out.
I've since shoved the BCPR6E plugs back in and they look much healthier upon inspection at 10k.
The 6's usually last 30-40k. 40k they really look worn but still work fine. :kiss:
  • 1 month later...
i just pulled my plugs out as im still having misfiring issues above 16psi and the are the bcpr7's gapped to 0.6 and the tips are white!!! they have only been in car for 5000ks
does this mean they are running too hot?
i have a set of 1.1mm iridiums in the 6 heat range, can these be gapped? the electrode looks pretty fragile :P
dea?
aarrgh now u got me worried.
getting another rb20 dropped in next weekend but need all supporting stuff working..
fuel pump has been pretty noisey lately! how can u tell if they are buggered? will a pressure regulator help the situation?
:P
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
