basic question.
non turbo 32. converting to turbo 32. are the looms any different? mainly engine harness ect.
ie . can i just change the engine ect use the std loom with the turbo computer. or are there big differences.
i know with s13's * my forte * becuase na sr uses a dizzy there are large sections of the loom missing , and the ca18 has all different plugs for alot of things
any help would be great.
`josh
https://www.sau.com.au/forums/topic/104408-r32-na-loom-questions/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
