interesting i just had the same prob .... changed the plug's and gapped them to .9 .... at first the problem was fixed but seems to change with different wieghts in the car ie 2 people as apposed to 1 etc.
Will be waiting on your finds :D DriftR_33
https://www.sau.com.au/forums/topic/104411-engine-fked/#findComment-1923207
Its better than having the issue i'm having now.. :P
Valve float.. Over 4000rpm with 12-13psi it will begin to miss, run on 5 cylinders. Brought down to an idle it will continue to miss until the lifters bleed back down.
Valve springs :D
Or you can machine the valve and make it lighter (no thinner than the thickness at the collet (sp??)
4000 is a bit low to have valve float unless someone was trying to do something tricky with the springs. More often than not I have seen double valve springs bind up at this point on modified heads. What springs did you install?
https://www.sau.com.au/forums/topic/104411-engine-fked/#findComment-1924018
I am running the stock RB25DE N/A valve springs.. I was hoping they would be good until 17psi, I had always planned on dropping new ones in to suit cams later on.
Sky30 ran his with no issues until 17psi with his N/A head untouched. He did however run a lower pressure pump than I.
Bl4ck32 is running 16psi with no issues BUT he has had his shimmed as Chris Milton Engineering did his head at the same time as mine, mine was apparently ok Bl4ck32's required shimming. Once again he too is using the lower pressure rb20det oil pump.
I'm using the rb25det pump that see's almost 8kg/cm3 (i think the unit is) at 4000rpm+. vs ~5-6kg/cm3 of the rb20det pump.
Maybe the higher pressure pump is slightly contributing to the pump up. I'm also running slightly thicker oil being the mobil 1 5w50.
I didn't experience as severe pump up with the motul 5w40, just power flattening out.
Thinner oil is not an option as its just a patch up. I wouldn't want to be holding third or fourth gear out without the valve transfering its heat to the seat well enough. :S
Either way.. I'm dropping a set of gtr springs in and will ensure seat tension is correct myself... As they say... If you want something done right.. do it your self.
https://www.sau.com.au/forums/topic/104411-engine-fked/#findComment-1924122
as soon as i accelarate, foot down it will beak up and miss...
light accelaration is ok... :(
about spark plugs, im pretty sure mine is 1mm or 1.1
[just the way they came]
now im running 13.5 psi do i change the gap to .8 or so?
https://www.sau.com.au/forums/topic/104411-engine-fked/#findComment-1924136
At 400rpm the oil pressure shouldnt matter as the lifters should be full prior to this and I dont think you can over pressurise them (within reason in a motor)
I agree that you should check the clearances and shim acordingly, but I would have hoped Chris Millton dit this correctly (he has a good reputation)
Have you had it on a dyno, just wondering if one (or two) lifters have sh!t themselves.
https://www.sau.com.au/forums/topic/104411-engine-fked/#findComment-1924142
Gap them at 0.8.
1.1 is a bit big for 13.5psi, and its an easy enough job to see if it fixes the problem. Whilst you have the plugs out, have a look at the colour and finish (their is a chart somewhere on the forums, or I can send you a copy of mine ) to diagnose any problems.
Inconsistency accross the range will help you diagnose a fault.
https://www.sau.com.au/forums/topic/104411-engine-fked/#findComment-1924145
Definitely .8mm is required... :(
Now back on topic... lol :P
The car has been on a dyno.... To myself I think it sounds like 1 cylinder that drops, I suspect cylinder 5 as I had an issue after the head was reco'd/worked...
The cylinders exh. valve seats were sitting higher than the rest, I spoke to Tim which said it is of concern and may cause detonation, it should really be fixed if you want to run 20psi+. Which was the origional intention.
I sent the head back to miltons, they fixed it with a bit of griping. Possibly they didn't bother checking seat pressure or just machined the valve seat and slapped it back in. The valve seat was definitely machined, not replaced.
I am going to defintely pull the head off and see whats going on. Replace all lifters, rb26 valve springs and setup everything properly.
I might prior throw it on the dyno again, get it to pump up then quickly pull fuel from that cyl and see what cyl is causing the problems. I should have done this last dyno session but ran out of time.
https://www.sau.com.au/forums/topic/104411-engine-fked/#findComment-1924178
I am not sure of the specs for the 2 types of valve spring, so this advice may not be relevant, but ....
Avoid the trap of putting in too heavy a spring. Heavy springs take more energy to operate, and have the added disadvantage of applying excessive pressure on the valves and seats (granted this is an equilibrium as the valves have to seat and the springs must force the valves shut at a rate close to the ramp drop of the cam.- too light and the valves may bounce or close too slowly)
The other component to consider when closing a valve (rather than high spring rates) is the reciprocating mass. This is an old trick where the shaft of the valve within the sleeve is machined down to the thickness of the Collet notch, (along the length that remains within the valve sleeve) as this section has no effect on the valves travel. By reducing the mass a lighter spring is required.
4000 rpm isn’t that fast, and you didn’t mention having a ridiculously aggressive cam, so my guess is that you have a sagging/broken/week spring, faulty lifter(s) or a bad valve that has prematurely tuliped,.
In any event it looks like its a cylinder head off job.
Good luck, and let us know what you find..
https://www.sau.com.au/forums/topic/104411-engine-fked/#findComment-1924268
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
