gday all.. i am new to SAU
i have.... wait for it.. a VL commodore.. i know i know.. but i have an RB20DET motor and box ready to go in. could someone point me in the right direction on a spec list on the motor figures ect.. and also how much boost could it handel with stock internals.. on the rb20 turbo and also if i switched to a rb25 turbo.
any help would be appreciated.
thanks heaps
https://www.sau.com.au/forums/topic/104459-rb20det-info/
