  • Replies 156
Posted Images
You beat me, oh well, lucky i think i may have found an alternative to buying Stagea specific indicators.... will test fit some S14 indicators some time in the near future.
Otherwise, friend in japan it is!
are you talking bout side or front indicators alex??
as l trial fitted a set of side indicators (as in the guard ones) from a pulsar and they pretty much fit fine, am going to have a chat with OZEparts first and see what else they have. Only problem with the pulsar one's is they are an extremely tight fit and take a bit of "persuasion" to get them in.
the guard ones are from R34/Maxima also, i'm using R34 ones on my car
Yup there the same ... as to for 200sx's.
Its strange, as knowing what nissan are like basically all parts they use on cars crossover to other cars, but atm l can't think of another nissan that has the same front indicators as the stagea does.
  • 6 months later...
  • 4 months later...
Well i got my new lights on today. i tell you what they're a bit of a bitch for the middle ones to get off. also the plugs didn't match, so i butchered my old lights loom and put them into the new lenses. they all work fine now. My old lights are for sale in the classified section if anyone is interested
Hi mate (Terminal or anyone with advice) - I'm halfway through fitting a set of series 2 rears to mine - got the corners on no problem - removed all the trim from the hatch and undone the nuts holding on the centre lights. Are they bonded on with something 'cause I'm struggling to get the buggers off? I don't want to break anything obviously and could do with some tips on getting these off damage free. Cheers :laugh: .
Yeah they have really sticky black adhesive. i got a screwdriver under them and levered them off. it's gross stuff and gets everywhere, but as long as you have all the bolts undone it will come off with some persuasion.
was wondering where you picked the set of taillights up from cos i am chasing a set to replace my cracked ones????
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
