Hey Guys,
I've got a Autogauge A/F ratio gauge and wondering where I should connect the O2 sensor?
There are 3 wires coming from the 02 sensor (off the dump pipe). Should I bridge it onto one of these?
or
Between the O2 sensor and the firewall?
or in the car cabin, closer to the ecu?
Also, the I ended up getting those smoke gauges so I need a constant 12V connection to power it. What would be the best place ti find such a connection?
Any help woild be great
Cheers
Sam
https://www.sau.com.au/forums/topic/104478-installing-airfuel-ratio-gauge/
Hey Sam,
Ok it's really easy. The red wire on your O2 is power, the black ground and the white is your signal wire. That's where you want to splice in to. Do not cut the wire, just peel back the cover and wrap your air/fuel gauge wire around it and tape the whole connection securely. As well do this prior to where the O2 sensor/wire harness connection is. That way when you have to change your O2 sensor you won't have to undo the wiring.
Now for a 12v switched power source you can splice in to your headlight controlls so when you turn your lights on at night, the gauges will dim like they are supposed to. Use a test light to locate that wire along with a good chasis ground and your all. The only wire that should be attatched to your O2 sensor is the signal wire from your gague.
I hope this helps out. ;)
Cheers B)
Thanks for that sidewayz. Exatly what I needed. I've decided to to run the power from the car stereo as the gauge needs a constant (whole the car is on) 12V as the gauge is one of those smoked gauges that dissapear behind darkness when not powered.
Ok we have a small issue
There is no Red/Black/Wire combo.
Coming out of my O2 sensore directly are 3 wires. Two white and one black
From the plug to to teh ECU after the plug (about 10cm up) the wires change colour to
Blue
Clear with brown wire
White with brown stripe
WTF?
It looks like mines been altered for whaever reason. Can someone please have a look at their sensor and tell me which wire on my O2 sensor wire combo corrosponds to the usual WHITE sensor wire please?
I'm assuming that the connections haven't changed...only the wire colour.
Here's a pic of what the femail plug running off my O2 sensor looks like (the clip is at the top)
Thanx in advance
Sam
i did mine a few months ago and i just spliced the signal wire into the clear copper wire ( the middle one in your pic ) .... i think its 12v acc that your after and just run it from the cig lighter ....
easy as!!!
Clear copper it was. Thanks guys and Thanks Tosh
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
    • As somebody who works in the energy sector and lives in a subzero climate, i'm convinced EV's will never be the bulk of our transport.  EV battery and vehicle companies over here have been going bankrupt on a weekly basis the last year.
    • With all the rust on those R32s, how can it even support all the extra weight requirements. Probably end up handling as well as a 1990s Ford Falcon Taxi.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
